587,189 active members*
2,430 visitors online*
Results 1 to 17 of 17
    Feb 2013
    RFQ - Small bespoke Router Table
    Looking for a quote to fabricate a small bespoke router table for model making. Have more information if you want to PM me. UK based but can arrange shipping from USA; only small parts.
    Dec 2003
    24223
    No small off-the-shelf tables in the UK? Rather than custom?
    Al.
    Albert E.
    Feb 2013
    cant seem to find anything to do this...
    as:-
    http://www.cnczone.com/forums/attach...s-cuttable.png
    im suprised too... assume the tool would be a dremel and its constrained x and y by use of bar slider rails.... move x and y by hand....
    thoughts?
    Dec 2003
    24223
    Seems to be similar to a trace cutting machine rather than CNC?
    Do you have the whole post link?
    Most of the posts here are those looking to build CNC in order to get away from the trace idea?
    Al.
    Albert E.
    Apr 2005
    175
    This looks like a pin router would work. What type of material are you going to be cutting (wood, aluminum ?)
    Feb 2013
    APPRECIATE HELP AL AND JOHN.. T H A N K S .. ;-)
    al..
    trace cutting machine?... WHATS THAT.. IM NO EXPERT...
    cnc at a later date (seperate) whereas this is a copy for original components (legacy)
    john
    pin router?. WHATS THAT.. IM NO EXPERT...
    the profile to follow is 5mm steel.. the copy need to be made in 5mm wood...
    see http://www.cnczone.com/forums/attach...s-cuttable.png
    ignore info in that original post...
    the x and y track allowing me to retain perpendicular to the part (good 90 degree edges) and moved by my hand.... the cutter follows profile of the metal and wood underneath.... may need to z move the cutter to allow profiles cut inside the metal (lift. move. drop etc) ... COPY NEEDS TO BE EXACT... DONT MIND ODD FILLET IN INTERNAL CORNERS; AS DERIVED FROM CUTTER BIT... BUT NEED SMALL CUTTER DIAM OF COURSE... probably 50-75 parts and need a good few copies of each...
    Feb 2013
    parts to cut no bigger than 10"x10".. please no pantograph or plunge router as that would wobble... the metal shape may be 2 plates connected together so no flat surface to metal (bolted together also... connected to wood same way.. to retain the sandwich as the cut made)...
    Feb 2013
    just connected a couple of example pieces... ignore the dusty pc! ;-)
    as image attached...
    Apr 2005
    175
    Feb 2013
    thanks john.. will review the infos... youre a good man ;-)
    Feb 2013
    ref the links... first comment... (not read all yet)
    as size is max 10 x 10 do i really need a router table?.. couldnt i attach a cutter (like dremel) and approach the shape from above?.. much cheaper im sure... also only cutting 1/4" wood.. thoughts?
    Apr 2005
    175
    Overhead or underhead. Just put the tracing pin on the table and fix the dremel (router) to an overhead arm. (just a reverse of the examples)
    Feb 2013
    trying to visualise
    Feb 2013
    friend just emailed me and asked why i couldnt have a scissor type 'thingy' to attach a dremel (or other if better) ... as attached image... looging down from top, left is the dremel and the x y movement comes from the scissor movement.. suggests if the scissor is jointed well is should not move at all in the z axis...
    then suggests this cuts the material somehow attached to any table required... even worktop at home.... thoughts?... see attached idea image he sent.. would need making i guess...
    Feb 2013
    just drafted this out... wouldnt this work?... dremel mounted .. hinge allows x y movement... piece to cut on table.. this fixed to table... think the dremel should then be constrained from z movement if hinged well..
    Feb 2013
    this guy seems to be on same wave length.. albeit not highest precision tool ;-) .. seems to do the job apparently... my stuff similar concept with the x y movement
    http://i361.photobucket.com/albums/o...r/DSC08457.jpg
    thoughts?
    Feb 2013
    i meant he doesnt have the needed x and y but rest similar..
  1. RFQ - Small bespoke Router Table
    By stonyme in forum EUROPE RFQ's
    Last Post: 02-13-2013, 09:58 PM
  2. Replies: 4
    Last Post: 03-01-2012, 02:50 PM
  3. Questions -- Small CNC Router with VERY SMALL Work Area, Ideas?
    By Building in forum DIY CNC Router Table Machines
    Last Post: 02-03-2012, 11:36 PM
  4. Planning small 3 axis router table
    By killersoundz in forum DIY CNC Router Table Machines
    Last Post: 12-03-2011, 08:32 PM
  5. Small router table on eBay?
    By Jeremy Harris in forum DIY CNC Router Table Machines
    Last Post: 12-22-2008, 04:32 AM
