587,704 active members*
3,559 visitors online*
Results 1 to 17 of 17
    Mar 2007
    534
    Chinese 40W Moshi/8051
    Hi
    I've just got one of these cutters and want to dump the Moshi software.
    The controller board is the MS10105 V4.1
    They have cleaned the name off the processor, but...
    Active high RESET
    Needs external RAM
    No prizes for guessing it's an Atmel AT89S51, or similar, running at 16MHz off a 32MHz rock
    It's been over 20 years since I did any 8051 programming, has anyone figured it out yet? Someone must be using them because RS still list them at about 2 quid a pop.
    best
    Robin
    Jan 2012
    53
    Re: Chinese 40W Moshi/8051
    I've just bought a board to replace the moshiboard from Chriscircuits.com which will allow you to use Mach3 instead. A nice and reasonably priced piece of kit. Not fired it up yet. Managed to avoid running moshidraw at all. The other option is a DSP from someone like Light Objects. More expensive though.
    No point adapting the current board really. Easier to ditch it. Unless you're really after a challenge!
    I'm based in the UK too, by the way.
    Mar 2007
    534
    I am going off this Moshi board...
    I was wondering what the big 150R resistor was for and I think it's the 5V supply and component D12 is a 5.1V Zenner. Weird, why would anyone do that when a 7805 has no problem dropping 24V to 5V and is hardly expensive.
    I think I got confused by the 5 Amp connector used to drive one piddling litte opto isolator on the Laser board. I thought it had to be a power connection, but it isn't.
    The other problem is the USB interface chip. I was expecting a serial to USB converter connecting to the 8051 UART but it isn't. It has had the markings cleaned off and it has a 8 bit bus connection. No idea.
    It isn't as if the board is doing anything clever, all it has to do is talk to the outside world, drive two steppers and switch the laser on/off.
    I think the entire board has to go in the bin. I have a spare ARM Coretex dev board which got trodden on demolishing the LCD touch screen, but otherwise okay. I already have a 4 axis control written for that, 2 axes should be a doddle. I could download the entire cut/engrave sequence to the on-board micro SD card and drag this dinosaur in to the 21st century.
    Mar 2007
    534
    Quote Originally Posted by Fred27 View Post
    Hi Fred
    You posted while I was replying to myself. Nothing like posting while buzzing out a circuit, takes time but gives you an incentive to get it right or look like a twit
    I am a control freak so I don't do Mach 3. Windows was never designed to do stepper motors and if something goes wrong I like to be able to fix it. Patching deep inside the vitals of XP to get around it is very clever but a bit fraught. I prefer Win7.
    I can cut dxf files nil problemo but the engraving part is trickier. Visual Studio will allow me to read in .bmp, .jpg, .gif and .png images. The .bmp sounds like the best option because there are no grey fuzzy bits. If I size the picture so pixels match the engraver step resolution it should be a doddle, all I will need is an offset and a speed.
    Sounds like fun
    Feb 2012
    I've love to be able to just swap the chip out instead of buying a replacement board.
    Throw in something like a PIC chip (pins will probably conflict a little so a daughter board?) with USB and implement a GCode interpreter program
    Mar 2007
    534
    Quote Originally Posted by acidice333 View Post
    That's what I thought.
    Replacing the processor is easy, the Atmel part will just slot in.
    Driving the steppers is easy, switching the laser is easy, reading the limits is easy, BUT talking to a PC is impossible unless we know what the USB chip is.
    I think it has to be a USB to serial adapter, but this guy is seriously out of date. I think he's found a part that doesn't require pre-programming for baud rates and frame. Hence the 8 bit connection. Without a spec sheet for the chip hacking it is not on.
    Sep 2012
    55
    i have a cheap 40w laser and I replaced the moshi software and control board with a simple stepper driver board and linuxcnc driven from the parallel port.
    Feb 2012
    Hopefully something is figured out soon
    You don't necessarily have to use the USB chip if you go with a daughter board that clips into the IC socket.
    So what if it adds a few more parts, at least its reusing the existing connectors and stuff.
    My moshi board died on me just today. Moshidraw sees it and says its `idle` but if I send any command it stays stuck as `busy`. When I turn on the machine it doesnt goto X/Y home position anymore. Eh its too bad I was just liking Moshidraw 2013 too I think its the main IC that died since if I remove it, nothing changes.
    Mar 2007
    534
    Perhaps you need to PM Fishface (message #7) who has a spare chip.
    If it was me I'd try changing the 32MHz crystal, always a good bet with a dead CPU.
    Is MoshiDraw 2013 an improvement? I downloaded a copy.
    I put the water pump in today and my laser now burns tiny holes in paper when I click the "Test Switch" but does that mean it is set correctly, it is a mystery.
    Did you find a helpful "how to use Moshi" instructions somewhere? I seem to be looking at a drawing package. It would be nice to see the laser at least try and do something.
    If You replace the processor then Moshi probably has to be consigned to the bin. I notice in "Systems options" it has IN; and PU; commands, suggesting the laser is working as an HPGL plotter, but that only helps if it comes up as a serial device.
    acidice333 Guest
    What would be ideal is if we can dump the firmware so if the chip fails we can program a new chip. The main IC failed on mine as I just bought a replacement 4.5v vs the old 4.1v board and tried swapping the IC over and it did try to home but seemed to ignore the home switches as they kept going so I didn't really do any more tests.
    I will later on go with a DSP but for now I'd rather use Moshi... Mach3 isn't ideal since I perfer to use a laptop and it doesn't work on my only laptop with a parellel port properly.
    ecpur Guest
    Aug 2012
    Feb 2012
    I would have loved to have his code and schematics so I could try this but it's been like a year since I posted a comment on wildcircuits and still nothing available from him
    Oct 2007
    385
    He is now active on the Buildlog.net site. He is building a large format laser.
    Milt
    Apr 2012
    12
    Mar 2013
    After the death of my MoshiDraw Dongle i'm searching for a alternativ software for the laser.
    No hope.
    Then i try to get some movement over the methode of wildcircuits with a Arduino, nope.
    Replacing the board with a 50$ parallel CNC stepper motor driver board Controller from ebay is easy but not my goal.
    The goal is: use the Laser with a Macintosh over USB.
    Now after 1 year the Laser work with a new driver board based on the Lasersaur Project.
    The board is a shield for a Arduino Uno.
    Runing on the Lasersaur software in a browser. Win, OSX and Linux are suported.
    I replaced the GeckoDrive G203V through stepper driver from Pololu.com
    Designed and tested is for both driver from Pololu the DRV8825 and the A4988. I use 1/8 steps.
    revision 0.1
    The end stops not work how i need. The software see the end stops but i can't use it to drive to zero. Zero is now the point where i put power on.
    The Laser need a low signal, Lasersaur say high. I'm inverting the signal on a smal plugin board. But PWM not work.
    I regulate the laser power with the potentiometer.
    The power cable from the laser and the ribbon cable still have a separate adapter board.
    The revision 0.1 of the board is a confusion but 0.2 will come.
    Mar 2013
  1. Working with Moshi 2012
    By mondo50m in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-24-2012, 06:52 PM
  2. Looking USB Key for Moshi USB Driver mainboard
    By cinematic2 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-05-2012, 11:38 PM
  3. moshi draw software
    By geekinesis in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-18-2012, 01:28 AM
  4. NewlyDraw VS Moshi Draw
    By blairgr in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-03-2012, 12:19 PM
  5. Oh Moshi!
    By nimming in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-07-2010, 07:55 PM
