587,262 active members*
3,445 visitors online*
Results 1 to 18 of 18
    Aug 2008
    199
    add laser on cnc for engraving
    hi everyone
    i have a jcut cnc machine which can go at 5 m/mn
    is there any type of laser head i can add just to engrave on mdf (draw logo)
    something i can add easily
    thanks
    for CNC woodcarving - 3d puzzle - furnitures
    http://pagesperso-orange.fr/fabrun/
    Nov 2010
    787
    With such slow speed you do not need high power.
    You may use smalest Synrad 48-1 CO2 laser. It is air cooled so there is no need to use liquid cooling system..
    But must remember that engraving will take long time.
    CNC lasers, constructions, service
    Oct 2011
    155
    Quote Originally Posted by fabconv View Post
    hi everyone
    Hang on.
    Is that 5 Meters per minute?
    Feb 2009
    6028
    Router dust and laser optics=bad.
    Router dust and source of ignition = boom
    ever seen a grain silo go
    best wishes
    Dave
    Nov 2010
    787
    Quote Originally Posted by Exsecratio View Post
    Have you ever heard about cleaning ?
    Or such magic machine as vacuum cleaner ?
    Best wishes too...
    Yup but very few remove sub micron dust particles
    That's why dust control in the UK is subject to ignition testing
    cheers
    Dave
    There is nothing you can add "easily" , the easiest and most probably cost effective solution is to buy a small to medium sized dedicated laser engraver/cutter from one of the chinese mnfgrs.
    Rodney , Cape Town , South Africa
    www.tokerbros.co.za
    Feb 2009
    6028
    Clean it all you want, any dust shortens the life of the optics by a bunch.
    Aug 2008
    199
    thanks for all
    it is 5 meters/min (5000 mm/min)
    about the synrad, how much does it cost approximatively?
    what speed can i expect ?
    A decent 30-50W synrad source will cost you round $3-4k for a new or newish one with some warrantee , then you need a Power supply for it and a controller of sorts , and then you need the optics You will end up with a lumbering "engraving" machine that is not really suited for purpose , takes forever to raster engrave (scanning back and forth) , is open and most likely in violation of any codeand dangerous , wont have fume removal and will have consumed a lot your time to set up and get right and might or might not be commercially viable.
    I have about 7 CnC routers and the same amount of Laser engravers , if it were easy or simple , I would have converted one of my spare CnC routers...
    www.tokerbros.co.za
    Nov 2010
    787
    thanks for all
    Do not worry.
    Rodney knows everything better and hates anybody having own mind.
    You do not need more than 15W laser becuse of slow speed of your router.
    48-1 can be bought for few hundreds. Remember new 48-1 have 16-17W. Used 10-15W. Less than 10W is waisting money.
    Power supply is standad 30V DC 10A.
    Tickle signal (needed for laser safe operational) may be generated by any source. You may buy Synrad UC-1000 or UC-2000 or make small Tickle generator.
    Optics may be chinese for few dollars/pc
    Aug 2008
    199
    thanks to help me understand
    is there anything possible with something like this ?
    Real 1W 445nm laser module/focusable/TTL [OL-445-1W] - $146.00 : Zen Cart!, The Art of E-commerce
    Nov 2010
    787
    Forget it.
    Nov 2012
    96
    What could a 1 Watt laser do?
    Nov 2010
    787
    445nm laser is VISIBLE blue laser good for visual effects like disco etc.
    You can try using it on specific materials but this is only 1W.
    Aug 2008
    199
    i'm asking this because this picture was made with this :
    Jul 2012
    83
    hey friend
    i know you need a laser engraver to do things like that,we have a mini laser engraver 400*300mm Jinan SPC Laser Co.,Ltd. you can think about it.
    and it's price is 2100usd,if you are intrested in it,we can talk about more.
    Susu:
    email : [email protected]
    Attached Thumbnails Attached Thumbnails 8-2.jpg   b26f419f-a405-4e0f-aec2-7f10a8341417.jpg   IMG_1103??.jpg   IMG_1109.jpg
  1. CMA-6040 Laser Cutting & Engraving Machine by Han's Yueming Laser
    By vksingh in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-10-2017, 12:53 PM
  2. Replies: 2
    Last Post: 04-06-2017, 05:17 PM
  3. Distinction between laser engraving between special LGP engraving machine when produ
    By CUTCNC in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-21-2011, 09:46 AM
  4. versa laser, laser engraving
    By cadmaniac in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-25-2010, 08:30 PM
