Originally Posted by
TiagoSantos
As some of you may have read on my other thread, I have a complete RF-40 and an almost complete RF-45. I got the 45 for a steal (I only needed the column) and it came with almost everything, BUT a table.
The plan for the moment is to convert the head to belt drive, get the Z axis ready for CNC, then move the 45 column and head to the old RF-40 which has already been converted.
BUT.. If I could find a table or something I can use as a table for the RF-45, I could use that instead, along with the slightly bigger base and longer Y travels.
I've tried a few sources for spare tables but doesn't seem like I'll have any luck. I've got a bunch of linear rails that I could use, so I'd settle for something I could adapt to the saddle with the linear rails rather than using the dovetails. I've even thought of a nice plate of steel that I could then surface on the machine itself and drill out a bunch of holes as a makeshift tooling plate. Tool steel is expensive, but a 3/4" x 10" x 36" plate of 1018 cold rolled is pretty darn cheap, and easy to machine.
