587,828 active members*
2,751 visitors online*
Results 1 to 2 of 2
    Jun 2008
    24
    Question Anilam 6000M - Fryer fatal motor error
    We have a MC-50 Fryer with Anilam 6000M. We are getting a fatal error
    Motor - 4 not moving at MAX motor power
    fatal card error
    Time out in finish sequence
    Any clues and we could use the name of a Service tech for Tampa-Sarasota area
    Nov 2012
    5
    Reply- Axis drive problem
    Sounds like your 6000 or is it a 6000i, has an internal drive problem, You can get a drive rebuilt from Anilam/ Heidenhain, pricey though... Fryer can do it but they just send it to Heidenhain anyway so why bother. You will want to remove your hard drive and install into the new unit if you can and it is still good. Saves headaches. good luck. I service these machines and occasionally get to your area if you need further help.
  1. Post Processer for Anilam 6000m?
    By matthew6060 in forum GibbsCAM
    Last Post: 07-26-2015, 08:21 PM
  2. CNC Program/set-up/Op Fryer Mill w/Anilam - MI
    By MachiningJobs in forum Employment Opportunity
    Last Post: 04-05-2011, 08:48 PM
  3. Anilam 3000 on Fryer VMC - 9.1 post???
    By underdog in forum Mastercam
    Last Post: 06-18-2009, 05:07 PM
  4. anilam 6000m
    By slug in forum Uncategorised MetalWorking Machines
    Last Post: 06-11-2009, 07:39 PM
