587,490 active members*
5,403 visitors online*
IndustryArena Forum > CAM Software > MadCAM > where is the menu for continuous 4 axis functions?
Results 1 to 5 of 5
    Jan 2009
    49
    sorry for the silly question but... I can't find the menu for the continuous 4 axis functions. I've enabled every MadCam toolbar, set the machine into 4 axis mode, and looked through the options ... how do I select, for example, continuous 4 axis parallel finishing as in the attached picture?
    Mar 2004
    1661
    Did you buy a 4-axis license?
    madCAM four axis intro - YouTube!
    Jan 2009
    49
    yes, I have the full 4+5 axis version, and I can successfully replicate your indexed 4 axis tutorial where you create two 3D toolpaths then switch the machine setup to 4 axis and it will cut one then rotate the A axis then cut the other.
    I just can't seem to find the menu of continuous 4 axis functions... attached is the list of toolbars I see. The only functions on the "4-axis and 5-axis tools" toolbar is axis setup and C planes... no cutting functions.
    Mar 2004
    1661
    The toolbar icon is the fourth in the MC 4.3 toolbar, called "Set 3.axis mode".
    Try to invoke it manually by writing "MadCAMCommand" and then "Select_Rotary_Axis". If you get the question to select axis you have the function available, but might need to check the toolbar again.
    Jan 2009
    49
    thanks Sven, yup I have that toolbar, and yes I get the question to select the rotary and spindle axis.
    ... discovered the explanation in the 4-axis section of the program help files: "[selecting the rotary and spindle axis] converts any toolpath strategy in madCAM to simultaneous 4 and 5-axis."
    So for indexed 4 axis we set options/axis-setup to 3-axis machine, then select "3 axis mode" from the 3-axis mode toolbar, then generate toolpaths, then change axis setup to 4-axis before post processing.
    For continuous 4 axis we set options/axis-setup to 4-axis machine, select rotary and spindle axis from the 3-axis mode toolbar, then generate toolpaths.
    thanks for your help and patience :-)
  1. 5 Axis continuous pocketing
    By JerryBradley in forum MadCAM
    Last Post: 06-18-2012, 01:30 PM
  2. Continuous Line
    By JCAcuraCL in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-27-2011, 09:52 PM
  3. Help Menu Missing
    By Lafaso870 in forum Uncategorised CAD Discussion
    Last Post: 12-03-2010, 08:13 AM
  4. 4th axis continuous machining software?
    By replicapro in forum Benchtop Machines
    Last Post: 02-27-2008, 07:26 PM
  5. 5 Axis indexed vs 5 Axis continuous
    By jwolin in forum Uncategorised CAM Discussion
    Last Post: 03-24-2007, 08:21 AM
