587,326 active members*
3,430 visitors online*
Results 1 to 10 of 10
    Aug 2010
    68
    Two axis rotation joint for two rods
    I am trying to come up with a simple joint that will allow me to connect two half inch diameter aluminum rods at a 90 degree angle, and which allows them both to both rotate freely, and then lock rotation on both. Anyone have any suggestions?
    May 2004
    4519
    These joints are generally gears.
    On second thought. Maybe you want a clamp block?
    Some people try, but end up being so vague with poor communication. Try a drawing next time.
    Dec 2003
    24223
    You need a Universal joint or Hardy-Spicer coupling.
    However you may need two together for 90°.
    Al.
    Albert E.
    Jul 2005
    12177
    Are this rods driveshafts or just for holding something?
    Aug 2010
    68
    Al.
    I only need around 35 - 45 degrees max. The U joints would have to lock in place once angle is set. Can you point to an example of a locking U joint if one exists?
    Aug 2010
    68
    Quote Originally Posted by Geof View Post
    No not a driveshaft. Just two rods on which a jig rests on. Jig sits on a table top.
    Aug 2010
    68
    Quote Originally Posted by txcncman View Post
    Yes that is exactly what I am trying to come up with...some kind of a clamp block that fits onto two rods.
    For a clamp block to work, I would need to mount both rods to the block, and while holding one rod perpendicular to a table top, this rod would need to be able to slide up and down along the Y axis - perp to the table surface, and the other rod would need to:
    a Rotate on it's lengthwise axis
    b be tiltable along the Y and Z axes by around 35 degrees on the X and 45 degrees on the Y relative to the perpindicular rod.
    Once set, the rods both need to be locked into position to the clamp block.
    I came up with a different idea last year, but I am trying to come up with a secondary idea maybe simpler or easier to set up.
    Jul 2005
    12177
    Have a look at the clamps and fitting used to attach dial indicators to the stem of a magnetic base. They are around 7/16" diameter not 1/2" but they perform a similar function of adjustment.
    Alternatively if there is a place near you that supplies wheelchairs you may find they have clamps and fittings for attaching small switches to wheelchairs so people can activate them with their head.
    Another alternative could be the clamps and fitting used to build equipment setups in chemistry laboratories.
    Aug 2010
    68
    Thanks Geof will check that out I think I looked at a few sites last year but could not find anything, I will dig some more.
    Dec 2003
    24223
    Without some kind of drawing it is difficult to know exactly what the constraints are?
    But if you just need a varying angle coupler that needs to extend on one arm and then clamp, a Universal coupler Lovejoy, Inc. : Products : Couplings & Power Transmission: Universal Joints
    And instead of an expensive splined shaft, a simple rod inside a tube as a sliding extension and to clamp a spring jig clamp or a toggle clamp?
    Is the clamping intended to be manual or automatic?
    Al.
    Albert E.
  1. Canadian suppliers for drill rods and threaded rods
    By deejayspinz in forum Want To Buy...Need help!
    Last Post: 08-31-2012, 10:02 AM
  2. best bearings configuration for z axis for manual wood joint maker
    By endgrainguy in forum DIY CNC Router Table Machines
    Last Post: 08-20-2007, 02:10 AM
  3. z axis rods and bearings...
    By project5k in forum DIY CNC Router Table Machines
    Last Post: 10-19-2006, 04:14 PM
  4. Proper size of Z axis rods?
    By simmonsk in forum DIY CNC Router Table Machines
    Last Post: 08-20-2006, 04:22 AM
  5. Dirt cheap Polyester PETP rods for Z axis???
    By andy_ck87028 in forum Linear and Rotary Motion
    Last Post: 06-20-2006, 09:45 AM
