Hey guys
Im looking at some design options for a 6’x3’ router table. In doing some math on forces involved, I realized- I have no idea what the stepper motors’ ratings are for the bending/shear loads they see in a direct drive approach (in a rack/pinion or “servobelt” implementation). If you assume a couple hundred pounds of linear force from a direct drive, you have that, but also with rack/pinion some cam forces are in play.
Seems like a non-issue, since there are many direct-drive systems. But, it seems possible that this is a source of slop in the drive (i.e. some deformation in a thin NEMA23 axle, or some runout in the bearings, etc). Are there published specs for motor tolerance to these lateral forces?
Regards
