587,827 active members*
3,122 visitors online*
Results 1 to 7 of 7
    Oct 2011
    141
    X3 Mill Built Home Robot
    Home robot built on my CNC X3 mill. It's built like a CNC machine! 2 steppers for the drive wheels, 3 steppers for the vertical actuators using 3/8-12 lead screws.
    Vertical saddles for the arm and center tablet computer were machines out of Delrin and ABS plastic. I was able to hold 1 thou tolerance on some saddle parts out of Delrin using Mach backlash comp and the CNCFusion deluxe conversion kit.
    Aluminum extrusion were also machined on the X3 mill.
    Motor drivers are a custom board using 3 amp bipolar 7128 ICs from
    北京海华博远科� �发展有限公司
    Stepper controller is an Arduino Mega board. Stepper ICs for drive wheel are in 1/128 step mode for low vibration and noise. To generate the 100KHz step signals I used hardware timers on the Arduino. Using the timer registers allowed me to "set and forget".
    I entered the robot into an Instructables contest sponsored by Jack Daniel's:
    A Robot In Our Homes
    Enjoy!
    Danh
    Dec 2010
    1230
    Very cool! looks fun!
    Jan 2010
    2141
    "You will be assimilated"
    Oct 2011
    141
    Quote Originally Posted by PriddyShiddy View Post
    X3 mill did good on cutting out the holes in the extrusions and cutting the Delrin spacers. However, cutting the 12" x 12" 1/4" ABS plastic pretty much went beyond the footprint of the X-Y bed. Gonna try a Shopbot CNC router on the ABS to speed things up.
    Oct 2011
    141
    Quote Originally Posted by doorknob View Post
    In such a scenario humans should hit the ESTOP button in the front of the robot ;-)
    Oct 2005
    2392
    That's why your robot overlord has arms! So it can cover up its e-stop button.
    Oct 2011
    141
    Quote Originally Posted by RomanLini View Post
    Talking about buttons
    This robot likes buttons
    Like the ones in a factory .....
    Part 1: Future Of Robotics: Manufacturing Gets A Makeover With Baxter - Forbes
  1. Home built CNC mill #2
    By jimglass in forum Uncategorised MetalWorking Machines
    Last Post: 04-03-2008, 10:29 PM
  2. Had You built CNC Plazma at home.
    By sanjiv in forum Waterjet General Topics
    Last Post: 01-10-2007, 05:44 PM
  3. Home Built Benchtop Mill
    By dcprecision in forum Benchtop Machines
    Last Post: 08-30-2006, 05:10 PM
  4. home built cnc router
    By sanjiv in forum DIY CNC Router Table Machines
    Last Post: 08-17-2006, 09:43 AM
