Heh, no - it's not speeded up (and I did apologise for the camera work...) Programmed feedrate was 9,000 mm/min, of course it will not maintain that at sharp changes of direction.
As Ray says, it's cutting wood - not a difficult cut by any means. My point in showing it was only to illustrate why a mill that can follow the programmed path accurately at higher feed rates might be beneficial when cutting complex 3D surfaces, that being relevant since the OP has said he cannot easily accommodate a 1,000 lb machine.
Regards,
Jason
