587,482 active members*
3,420 visitors online*
IndustryArena Forum > CAM Software > CamWorks > Camworks generate bad G-Code
Results 1 to 8 of 8
    May 2012
    I'm trying to generate a G-Code file from a piece in Solidworks, using Solidcam.
    When I simulate the toolpath with Camworks, everything is perfect. But with the generated G-code, that's an other story ... It add some big circles in the toolpath. And I don't know why ...
    I'm using Mach3 on my CNC. I used "fanuc" postprocessor.
    On the first picture, this is ma part. And the second picture is what it's look like in Mach3.
    Does anyone have an idea ???
    Thanks ...
    Nov 2009
    11
    Its either a post processor config or a mach3 config problem. Post your part file and gcode and I will take a look.
    May 2012
    As you asked !!!
    Thanks !!
    Attached Files Attached Files
    Nov 2009
    11
    Ok,
    I have downloaded your files and will take a look as soon as I can. I might not post back for a day or two.
    Nov 2009
    11
    Actually,
    There is nothing wrong with your gcode, it plots fine in the few fanuc ploters that I tried. It seems your Mach3 doesnot like fanuc format? Maybe it doesnt like the I & J words?
    Jun 2007
    3735
    In Mach3 set IJ mode to incremental (General config, IJ mode) or add G91.1 at the start of the code to do this in the program.
    You can configure the CAM program to use absolute arc centers instead of incremental.
    Super X3. 3600rpm. Sheridan 6"x24" Lathe + more. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
    May 2012
    Quote Originally Posted by adamw View Post
    Actually,
    There is nothing wrong with your gcode, it plots fine in the few fanuc ploters that I tried. It seems your Mach3 doesnot like fanuc format? Maybe it doesnt like the I & J words?[/IMG]
    Thank you for your time !!!
    Quote Originally Posted by neilw20 View Post
    I've just made a test... And It's working well !!:banana::banana:
    Thank you very much !!!
    Aug 2008
    1186
    Re: Camworks generate bad G-Code
    I was wondering if you might share your lathe post, I'm having similar issues and would like to get something closer than what I have come up with using the UPG and a Siemens post as a starting point.
    Thanks!
    Chris
  1. Is there a way to generate CL code in Solidcam
    By manussim in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 02-02-2021, 07:02 PM
  2. Generate g code with solidworks
    By romarlo in forum BobCad-Cam
    Last Post: 04-04-2014, 09:50 PM
  3. Looking for someone to generate me some code
    By JerryFlyGuy in forum Vectric
    Last Post: 08-17-2011, 11:29 PM
  4. What tools generate G-Code
    By eskimobob in forum LinuxCNC (formerly EMC2)
    Last Post: 09-30-2008, 02:54 AM
  5. Best way to generate code?
    By jderou in forum BobCad-Cam
    Last Post: 09-29-2004, 02:37 PM
