587,278 active members*
3,178 visitors online*
Results 1 to 6 of 6
    Aug 2012
    0M Cutter comp
    I have a Daewoo VMC with a Fanuc 0M control. The only way I can get the cutter comp to work properly (not crashing) is to use G1 G3 G41 in the same block. I have never seen G1 and G3 in the same block on other machines. My post for my programming software will not generate a program with a G1 and G3 in the same block, so all I can do is program manually at the machine. There were some old programs in memory when I got the machine, that is how I found out how it has been working. Any help or ideas would be much appreciated. Thank you
    2932
    Quote Originally Posted by millguy63 View Post
    G1 and G3 cancel each other out. You should only activate G41 or G42 in G00 or G01 mode. Same for cancelling with G40.
    Why not post your program here so we can see what might be causing the problem.
    Aug 2012
    sample program
    This is a simple tool path I copied and pasted. G1 G3 and G41 are in the same block. If I delete the G3 it will not turn the cutter comp on. If I delete the G1 it will make an arc movement but still not comp properly.
    N2T27M98P8
    ( TOOL 27- .187 FINISH ENDMILL )
    G17G80G40
    G56
    S1833M3
    G90G0X.1448Y-.062
    G43Z5.H27
    M8
    Z.1
    G1Z-.125F5.5
    G1G3G41Y.125D57
    G1X-.875
    G3Y-.125J-.125
    G1X.1419
    G40Y.062
    G0Z5.
    M9
    G91G28Z0.
    M5
    M30
    May 2004
    4519
    Most CNC machines will not allow you to start cutter compensation on an arc move. Must be done on a linear move. Same with cancelling.
    2932
    N2T27M98P8
    G17G80G40
    G56
    S1833M3
    G90G0X.1448Y-.062
    G43Z5.H27
    M8
    Z.1
    G1Z-.125F5.5
    G1G3G41Y.125D57 <----------- removed G3 and it backplotted fine.
    G1X-.875
    G3Y-.125J-.125
    G1X.1419
    G40Y.062
    G0Z5.
    M9
    G91G28Z0.
    M5
    M30
    With the G3 in the G41 block it backplots ugly. Removing the G3 solved the problem. What value do you have in D57?
    2932
    Hmmmmm. millguy63 musta taken off on holiday or somethin'. Hope he got his problem figured out.
  1. cutter comp in G91
    By KEENANDOG1 in forum Haas Mills
    Last Post: 10-08-2011, 08:40 PM
  2. Cutter Comp.
    By camtd in forum G-Code Programing
    Last Post: 05-25-2011, 05:13 AM
  3. cutter comp
    By mdred68 in forum Tormach Personal CNC Mill
    Last Post: 11-07-2010, 08:40 PM
  4. G19 Cutter Comp
    By smaida10 in forum G-Code Programing
    Last Post: 02-24-2010, 03:09 PM
  5. Cutter comp on an id hole< cutter diam.??
    By PaintItBlue in forum Haas Mills
    Last Post: 05-06-2008, 12:30 AM
