Greetings! I was curious to know if it makes any difference if the spindle key is ground off shorter so that it will not make any difference in which way the tool is loaded in the spindle? Recently took a job at a company that grinds all of the keys so that operators will not accidentally load a tool the wrong way causing a tool loading jam. They have Johnford mills, Yang mills, Cincinnati mills, and Hardinge/Bridgeport. All of the keys have been modified and have been in use for several years. So, just wondering why there would be a difference in the first place?
Thanks,
Mike
