587,647 active members*
3,621 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > best cutter for cutting out letters in mdf
Results 1 to 9 of 9
    Dec 2011
    I have been looking at various sites looking for the best cutter for use on MDF. I need to be able to cut out names/letters out of 1/2 thick MDF.
    After going to sites like toolstoday and noticing all the different tools i want to make sure i buy the right one for the job and not spend money trialing different ones. Something around 3mm to 6mm in diameter is required.
    Any links and info on the best bits/end mills would be greatly appreciated.
    Mar 2012
    276
    V bits are what you want for text. Have you seen the program F-Engrave? Nice and simple.
    Dec 2011
    I need to cut out whole single letters and names out of 12mm thick MDF so i will need a cutter to be able to cut all the way through 12mm thick MDF.
    Mar 2012
    276
    Ahhhh, I misread. Carbide Cutter. This bit here is like the sharpest bit I own. Eats through hardwood like its nothing. It will laugh at MDF.
    35538
    2 flute downcut spiral.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Feb 2009
    95
    Yep, and good dust extraction.
    Jan 2012
    34
    Quote Originally Posted by Dragonfly View Post
    And don't forget to leave the cut letters attached with tabs to stop them being damaged by being thrown around by the cutter.
    Dec 2011
    Just purchased some 2flute down cut spiral from toolstoday. I have also v carve so i will have to learn how to add tabs to my name tags.
    I would not bother cutting MDF if it was not for a dust extractor as it coats everything without it.
    Feb 2009
    95
    I had in mind that down cut spiral end mills tend to compress the chips which may lead to higher temperature from friction and some good suction is needed on relatively deep cuts. The positive side is that they do not produce lifting force which tries to lift the material.
    The tabs are really a must but I use CamBam and can't help.
  1. Replies: 3
    Last Post: 06-09-2012, 05:28 PM
  2. Help Needed with cutting Letters
    By RobinJohn in forum Uncategorised CAD Discussion
    Last Post: 01-06-2012, 09:54 PM
  3. Cutting letters with outlines
    By neonlady in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 10-21-2008, 05:48 AM
  4. Cutting 2" Foam letters
    By routski in forum Material Machining Solutions
    Last Post: 01-10-2008, 11:57 PM
