So I have a bandit I have been trying to work on it for quite some time with no forward progress. It sort of powers on. I took the cover off the top and depressed a switch next to the 115/230 selector switch. It appears to be a breaker of some sort. I have a red Reload light come on and a red Reset light also that is in the front of the panel. Inside the control there are 2 cards that have led's one card has 6 led's and that has the 3 XYZ led's lit up under the word Null. The other card has a single red led that is lit up that I haven't determined what it is yet.
I have tested the power supply and I believe that is the culprit. There is power coming out of 4 of the 6 leads on the transformer. I'll have to verify what letters and the Volts coming out of them. I can't remember off the top of my head.
So anyhow I found a power supply for a bandit on ebay. It's kinda pricey and I was wondering could I just replace my transformer and get it to work? If I choose to buy the one on ebay are they interchangeable? It looks like an older version of the power supply I currently have. My transformer is a Power One with 4 wires going in and 6 coming out. I believe the ones going out are A AT A B BT B the wires going in are 1 2 3 4. I really need some guidance here as I have no knowledge of what transformer to buy to replace it. I understand a little bit there is a chart on the back of it that tells me the way it's wired and what Volts and Amps it will output based on the different configuration. Any help, insight, or info would be greatly appreciated.
