587,608 active members*
3,359 visitors online*
IndustryArena Forum > MetalWorking Machines > EMCO CNC Machines > EMCO Lathe > help:alarm 480&487 for emco maxxturn 65 fanuc 18i
Results 1 to 3 of 3
    Oct 2006
    12
    Exclamation help:alarm 480&487 for emco maxxturn 65 fanuc 18i
    hi i no this is dump but i have to ask
    i just moved to another cnc workshop and while starting up this machine and then referenced all axis i switched off the machine
    now the machine cannot go to referance place because it is there
    and the alarm displayed is 480 and 487 as listed in images
    so the question is
    how to move the machine manually to re-referance the axis
    Attached Thumbnails Attached Thumbnails 2012-06-17 09.17.14.jpg   2012-06-17 09.17.22.jpg
    solution of this alarm
    You first have to sure that what type of encoder are you using... it is a incremental encoder or a absolute encoder. If it is a incremental encoder then it will not store the value of reference point after switch off. and you should return the axis to the opposite direction of reference point to de attach the reference dog. Once you have done it then you can re reference the axis again. It will happen after every switch off.
    absolute encoder store the value of reference point. if you use this type then be sure that the battery power of encoder is ok.
    If this can solve your problem i will be happy.
    For more cnc related problem pls visit CNCmachinetools.org - Everything about CNC machines, tools and components
    Feb 2013
    23
    Re: help:alarm 480&487 for emco maxxturn 65 fanuc 18i
    Hello,
    I just ran in to the same issue, when for some reason the x-axis was able to move way up but did not respond when I tried to jog it the other way.
    I also had the 410 alarm before.
    How did you overcome these errors eventually, assuming you found it?
    Thanks in advance
  1. EMCO MAXXTURN 65 alarm 2079 TURRET referencing failure
    By samirabaza in forum EMCO Lathe
    Last Post: 04-07-2014, 04:15 PM
  2. Replies: 0
    Last Post: 02-13-2014, 09:46 AM
  3. Emco 340 Alarm
    By WIRE CUTTER in forum EMCO Lathe
    Last Post: 04-24-2011, 05:12 PM
