587,431 active members*
3,133 visitors online*
Thread: Weight
Results 1 to 7 of 7
    Nov 2008
    36
    Weight
    Does anyone know about how much a 1/2 full 55 gallon drum of 15-5 solids might weigh
    May 2004
    4519
    You can only estimate it unless you want to fill the voids with water, then drain the water off to get the empty volume. Even then you are only going to get close. I think steel weights 0.098 pounds per cubic inch. 1 gallon is 231 cubic inches. 55 gallons times 231 cubic inches per gallon is 12705 cubic inches. 12705 cubic inches times 0.098 pounds per cubic inch is 1245.09 pounds. So a solid piece the size of a 55 gallon drum would be 1245.09 pounds. A solid piece 1/2 of a 55 gallon drum would be about 622.5 pounds. You know you have something less than that (plus the weight of the drum itself).
    Jan 2006
    2985
    Jeff
    You can get pretty darn close with a bathroom scale. I attached a picture to explain. You just need to weigh all four corners, add them up, then subtract the weight of the pallet and the drum to get you net weight. I use this method when I ship stuff freight, once I get to the depot, I'm normally within 10 pounds of their weight. You can weight up to 4x the scale capacity this way, probably at least 1200 lbs for most scales.
    Matt
    Nov 2008
    36
    Thanks for the reply's
    Jan 2006
    2985
    According to google, steel is around .28 lb/in^3. Aluminum is closer to the .098 stated above. So txcncmans numbers are about 1/3 of what they should be.
    Matt
    May 2004
    4519
    Quote Originally Posted by keebler303 View Post
    Matt
    Sorry. I should have actually checked the number. See what happens when you rely on memory?
    Jul 2005
    12177
    Rounded to one figure aluminum is 3 x as heavy as water and steel is 8 x as heavy. A 55 gal drum full of water is about 500lbs so 'full' of steel it would be about 4000 lbs. Allow 50% for voids because the chips are not solid, maybe more than 50%, and you end up with not more than 2000lbs for a drum full.
  1. shizuoka AN-S weight
    By sno-pro79 in forum Knee Vertical Mills
    Last Post: 03-13-2012, 06:10 PM
  2. SX2 Head Weight
    By FunkedOut in forum Benchtop Machines
    Last Post: 08-30-2011, 11:42 PM
  3. Weight Restrictions
    By BlkNotes in forum Taig Mills / Lathes
    Last Post: 05-23-2011, 07:37 PM
  4. How much weight do you think it can handle?
    By protrxrptr17 in forum MetalWork Discussion
    Last Post: 12-01-2006, 09:54 AM
  5. Line weight
    By JOE65 in forum Autodesk
    Last Post: 05-21-2003, 05:31 AM
