587,743 active members*
3,206 visitors online*
Page 1 of 2 12
Results 1 to 20 of 21
    Jul 2003
    126
    Plasma tube notcher?
    I am slowly collecting parts for a CNC plasma table.
    Cutter is on order, servo motors are here.
    Had a thought. Could I add a 4th axis to rotate tubing and notch it. (also called fishmouth)?
    Right now I use my mill with a roughing end mill and set the tube in the vise at the angle needed.
    Thinking if you could map out the appropriate geometry, you could rotate the tube and plasma cut it to acheive same result but quicker.
    Also short of trial and error for the profile, is there a way to calculate it without a ton of calculus?
    Jan 2004
    490
    Just set a chop saw to 30 deg, cut one side, turn over and cut the other side, sharpen the edges with a grinder. If I were better at CAD, I'd draw up some diagrams for you to see. Easiest way to notch tubing, if you plan to weld it together anyway.
    Stop talking about it and do it already!!!!!
    4826
    If the tubing has a significant thickness, such that you would be concerned about the actual angle of inclination of the cut, the rotary axis working underneath a fixed plasma head would give you a cut that was normal to the tube axis throughout the rotation. This might not be what you want, as it would not be equivalent to what your endmill cuts exactly.
    On the other hand, you could incline the plasma stream a bit (if they will cut that way), to cut a sort of cone-shaped end on the tube. This might fit up a little bit better, but still not as good as milling it.
    So for best results, you might also need one degree of freedom on the plasma head, so that it can precess properly as the tube rotates beneath it.
    As for calulating the path, even for a 4th axis wrap, it beats me how you'd do it. It might not be too bad if you only cut 90 degrees at a time, then indexed it. For this, you could use solid modelling to create the profile edge you would need.
    Jul 2003
    126
    Hobbiest: I think your term notching and mine are slightly different.
    I need to notch them so they intersect another tube midstream.
    Probably most known case would be a car roll cage.
    HuFlung: Yes, thought about the angle deal. Being I am welding them, and tubing is .125 max thickness I don't think it will be a big deal.
    Here is a picture of what I am building. You can see tubing intersects with the bushings.
    Jan 2004
    490
    No...that is exactly what I mean by notching. This is how we build handrails out of pipe. It is the easiest way to cope tubing to fit it together. Takes a little trial and error, but works great for welded joints.
    Jun 2004
    43
    I have thought about the same thing, I think it would work well with the right software to quickly create the code.
    I designed a tubing vise to use on a mill-drill to fish-mouth 4130 tubing for racecar chassis'. It is nice because you can set the angle quickly and accurately, plus cope off center. The typical fish-mouthing tools sold use hole saws and don’t have that feature. This tubing vise I designed has a bushing that fits counter bores on the center of the rotational axis on the V block and vertical mounting plate. An angle plate makes it easy to mount to a machine table. There are marks engraved every 1º, the range of adjustment is 95º. It locks in position with a 1/2" bolt through the slot, with the bolt threading into the V block.
    With stops and or some more structure, it could actually work fairly well for repetitive cuts in a production environment. Most race chassis are hand built to fit a certain body, so the need to make multiple identical parts isn't great.
    The cope on a good tube joint has to fit very well so the weld joint is tight and even. For one thing, you don't want to fill big gaps with a TIG weld on a 4130 chassis; it isn't of good enough quality. I use hole saws with custom made arbors, you want something like a 3/4" shank for rigidity, and you can chuck it in an R8 or similar collet. The hole saws actually work quite well, since they are only cutting a thin kerf compared to an end mill it is easier over all. That’s a piece of 1-1/2” 4130 .080” wall tube in the picture for size reference.
    I have used CNC's and a ball nose to cut fish-mouths for acute angles, where the joint was about 10" long. In that case I programmed it with 3D software. It is slow and I wouldn't want to do production work that way.
    There is one heavy-duty commercial tubing notcher made that uses large end mills and a sliding feed table, much the same a dedicated mill. I forgot the name, but it might be a good alternative.
    Jan 2004
    490
    TIG welding would definately be difficult with a gap. I have mig welded pipe coped in this fashion with incredible strength results however. On the machine you designed, what actually did the cutting?
    Jun 2004
    43
    I use the fixture mounted to a mill-drill table. Most hole saw arbors have a hex to chuck in a drill, so I made a heavy bi-metal hole saw arbor and chuck it in a 3/4" R8 collet. I use the "old" style hole saw, without the built in hex shank. Then its just a matter of adjusting the holesaw to tube relationship to where you want it. It's fairly fast on the cuts, and the fishmouth only needs a light deburring to finish. It's nice to have good tight joints, because it make the fixturing and welding simpler.
    Mar 2004
    18
    Aug 2004
    16
    I just mentioned this on another thread, but it applies here as well- with auto torch height on your z axis, there is no need for 4th axis indexing, at least on small pipe. Maybe if you were cutting 12" diameter pipe, but it gets expensive and complicated to rotate the 4th axis- industry standard is a Haas rotary indexer, and they get about $5500 bucks for those.
    My store bought C&G plasma system has a voltage sensor on the torch that runs the auto height on the z axis, and it has about 4" of vertical travel. This is plenty to birdsmouth, or notch, pipe or tubing up to 2" or so. Yes, the orientation of the plasma is vertical, but so is the end mill you are talking about- so it should give about the same result. A little less precise than an end mill, but a lot quicker.
    Apr 2003
    170
    Tube notches
    If your looking for a hole-saw type notcher, I can recommend this one from Pro-Tools.
    http://pro-tools.com/hsn500.htm
    It's a well built piece, and simple to use.
    TimeWarp is on the right track with this links. You can use the calculator to generate the necessary unwrapped profile of the intersecting tube, make a DXF from it and toolpath it. There is no need for a torch height controller if you don't have one. Set torch at .2-.3" above crown of tubing.
    Notching tube with a plasma CNC is gorgeous! You can do most notches (or fishmouths...or mitering) in a matter of seconds compared to several long minutes of setting up each one on a mill, drill or lathe. For instance, it would take just less than 6 seconds to fishmouth a 3" diameter tube with a .125" wall thickness on my machine with 4th axis.
    The finish cut is absolutely dead on, burr-free/smooth and ready to weld. There are no gaps between intersecting tubes provided that your torch is dialed in and you are not showing excessive bevel on the inside wall. They TIG together beautifully.
    If you are doing less than 10 notched tubes, then use a mill-based tubing notcher. However, if you are in production mode and are making bicycles, motorcycles or roll-cages, then the plasma with 4th axis makes the most sense.
    -Brady
    Nov 2004
    69
    Why not a very simple CNC tube notcher ?
    I mean a machine with only 2 stepper : rotate and tanslate.
    Manual eight of torch setting.
    Any idea? Is someone using a similar machine? what software?
    Oct 2005
    27
    Quote Originally Posted by ciccio
    Think of the tube as unrolled into a piece of flat. X axis rotates the tube, z axis moves the cutter back & forth. I reckon it would be pretty doable!
    Serious cool factor too, but unless you are doing a LOT of notching, and you NEED the notches to be spot on, it would be kinda hard to justify.
    But hey, it's not like I NEED a CNC flame cutter and i'm still pretty keen to build one of them
    Damen Stevens
    Brisbane, Australia.
    "Measure, then cut, then swear, then measure & cut again"
    http://www.cnczone.com/forums/showthread.php?t=13958
    Nov 2004
    69
    Hi, metalfab 101,
    ....I have to build 4 fuselage with 4130.....
    Any good CNC idea?
    Tube notchers ( tested for prototype)are not very precise for TIG welding, and time consuming.
    What software do you suggest?
    Nov 2003
    16
    has anyone looked at the Torchmate tube notcher. It is an attachment for the plasma table. It looks pretty cool. www.torchmate.com
    Oct 2005
    27
    Well, i'm only pretty new here and am really only thinking on the "theory level", i just don't have the experience to be able to suggest what software would work. In thinking about it I think you would have to allow for the diameter of the tube, eg, say you set your software to consider the x-axis as the rotation of the tube. If the diameter of the tube is larger that would make the x-axis longer. Therefore the x-axis would have to spin the tube faster in relation to how fast the y-axis is travelling for a larger diameter tube.
    From what I can tell when a XY table is set up it needs to be "tuned" so that the x and y axes are travelling at as close to the same speed as possible. On an XY table you would only need to do this once I would assume, but for a tube notcher you would need to configure this each time you changed the diameter of the tube you were wanting to notch.
    Please keep in mind I am very new to this and am just thinking out loud here. If I am totally off base please let me know.
    Damen Stevens
    Nov 2004
    71
    I think that you would first draw it in CAD as a line. The distance from start to finish would be the circumference of the tube. The line would be a series of arc segments, like a wave that had an amplitude of 1/2 diameter. Two peaks, two valleys. This would then be converted to g-code. The rotary axis would be calibrated so that 360° would equal a circumference. Then run the machine as a 2 axis, x could be rotary and y the torch. If you made the basic file, it could be scaled either way for bigger or smaller tube. I have fooled with scaling in TurboCNC by fudging the steps/inch. I'd like to see the fixture for turning the tube with a stepper. Anybody got a pic of one ? I personally use the mill with a roughing bit the diameter of the tube. It does do a perfect job, and I can notch bent tubes. When I notch big stuff, I do need alot of room around the mill (rollbars etc). Good luck, MIKE
    Oct 2005
    27
    Quote Originally Posted by accuratemike
    First thing that popped into my head was a 3 jaw lathe chuck.
    Then I thought, why not retrofit this onto a lathe? But I don't think you wan't plasma dust & dross/slag all over your lathe bed/ways.
    Damen Stevens
    Nov 2005
    1
    MD,
    You are using a holesaw with a 3/4" shank arbor gor your tube notcher, You might want to try an annular cutter from a mag drill. They are pricey, but last a long time and are resharpenable. Plus, like with the holesaw, you are only cutting the outside of the circle but you'll get the accuracy and cut quality of an endmill. i use these in my drillpress all the time for drilling plate, and have used in my mill with a 3/4" r8 collet for things that have to fit up real tight.
Page 1 of 2 12
  1. Plasma G-code with Artcam?
    By coherent in forum ArtCam Pro
    Last Post: 11-23-2006, 02:31 AM
  2. What to buy from rutex to get going........
    By Apples in forum Rutex Products
    Last Post: 03-01-2006, 05:05 PM
  3. How to weld plate to tube at 90 degrees?
    By coolman in forum Welding Brazing Soldering Sealing
    Last Post: 12-23-2004, 09:03 PM
  4. RF shielding against plasma
    By HuFlungDung in forum DNC Problems and Solutions
    Last Post: 11-18-2004, 04:36 PM
  5. Plasma cutting mdf.
    By ynneb in forum Waterjet General Topics
    Last Post: 11-06-2004, 02:56 AM
