587,215 active members*
3,252 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > How to adapt metric ballscrew parts to 80/20 Fractional series?
Results 1 to 4 of 4
    May 2012
    So I'm planning a new build of a 48x30 cnc router made primarily of 3030 and 1545 series 80/20 aluminum extrusion.
    I'd like to use a ballscrew assembly with the MBA style mounting bracket, with the FK, MGD, and BF style support blocks for the ballscrew assembly. (see image)
    The problem I'm having is this ballscrew assembly (and all the inexpensive ballscrews on ebay) are only available in metric series.
    How can I attach this assembly to my fractional series 3030/1545 frame? I spent hours online looking for stepper motor mounting brackets, but couldn't find any that are specifically designed to adapt the stepper motor to the 80/20 extrusion.
    Do most people just fabricate their own mounting plate or adaptor bracket?
    Nov 2010
    520
    This is exactly what I am working on now. My machine is made using the 8020 (15 series) extrusions. I just ordered a ball screw from Misumi and it is metric. The solution I am using is to make my own interface pieces from 1/2" plate aluminum. Basically the ball screw piece is mounted on the 1/2" alum and then this is mounted on to the 8020 extrusion. I am also going to use this 1/2" alum to mount the steppers. This is by no means my own idea as it has been used on countless 8020 machines.
    1/2 mdf is an excellent material to make mock-ups of the alum interface pieces. It's easy to cut and glue together using CA (super glue).
    I need to update my build thread, but spring projects are getting in the way.
    Rick
    PS. here is my build thread.
    http://www.cnczone.com/forums/cnc_wo...ter_build.html
    Jan 2006
    2985
    aluminum, a nice band saw or jig saw and a drill press and you can adapt about anything. You could consider buying standard 8020 plates and then just drilling/tapping the holes you need. May be quicker than making your own if you don't have the tools you need.
    Matt
    Feb 2009
    1290
    I'm interested in this as well. I will be watching you build thread Rick.
    Thank You.
  1. How to confire Mach 3 (metric) when my ballscrew 1 inch pitch ?
    By Calico in forum Machines running Mach Software
    Last Post: 12-22-2008, 02:24 PM
  2. Metric or Fractional T-Slot material?
    By jeffmorris in forum Joes CNC Model 2006
    Last Post: 08-25-2008, 08:43 PM
  3. Trying to find ballscrew to stepper couplers. Metric to Imperial?
    By thkoutsidthebox in forum Linear and Rotary Motion
    Last Post: 08-11-2008, 05:47 PM
  4. Adapt NEMA-frame motor to Metric?
    By cnczoner in forum Uncategorised MetalWorking Machines
    Last Post: 04-03-2008, 08:22 PM
  5. Where to get metric bearings for ballscrew?
    By gentoo in forum DIY CNC Router Table Machines
    Last Post: 12-22-2004, 09:00 PM
