587,487 active members*
3,724 visitors online*
Results 1 to 5 of 5
    Apr 2012
    35
    Laser Head won't move along Y axis...
    Hi again,
    It looks like I have a really bad product bought because everyday I have a problem with it. From yesturday laser won't move along Y axis. I've tryed to restart the sistem but it's not helping even though that moved a few times and after that the same.
    And I've tryed to engrave or cut but still won't move or it'g going up and down on Y axis with a lot of vibration.
    So any ideas about this please???
    Goran
    Driver card or motor for the Y axis is either on it's way out, faulty or has a loose connection.
    Swap the wires over with the X axis card and see if the problem travels with it, if so then it's the driver and not the motor.
    best wishes
    Dave
    ps: remember the pad controls will also be swapped if you swap the wires over. ie: X will become Y and Y will become X
    Apr 2012
    35
    Well I already try that and probably the card is dead. Even that the head is trying to move there is problem with the power I guess. However if there is something more that I should know please for info before I start whatever I'll do.
    Goran
    hi
    i think maybe you need to chec the power supply.there is a switch.tomorrow i will send you the pic for your reference.
    Abby
    [email protected]
    [email protected]
    Skype:abbylilu
    Web:laser engraving machine?laser cutting machine?cutting plotter at G.WeiKe
    Pls check the pic.It is the correct driver setting.
    Abby
    G.Weike Laser
    [email protected]
    [email protected]
  1. Laser Head
    By bundysax in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-05-2012, 09:00 PM
  2. JSM-40 laser won't move properly
    By Snarkhunter in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-29-2012, 02:57 AM
  3. How to move a large laser
    By tubeguy in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-01-2011, 03:01 AM
  4. Bone Head Move
    By BlueFin in forum Tormach Personal CNC Mill
    Last Post: 11-12-2010, 10:48 PM
  5. what size stepper to move head?
    By Runner4404spd in forum Charter Oak Automation Support Forum
    Last Post: 09-07-2006, 08:01 PM
