587,480 active members*
3,224 visitors online*
Results 1 to 3 of 3
    Dec 2011
    8
    warthog to mcah 3 conversion
    Ive laid out the pin configuration to go from the old warthog software to mach 3 . The machine im working with has anaheim automation steppers and a anaheim controller , i can make x y z move but they jerk and jump nonstop. Ive gone into the motor tuning screen and tried to tune them but spec wise i cant find anything on the net about these motors other then size and oz. They are aneheim automation model 34d207s steppers.
    One thing that did have me confused is pin # and pin dir, on the controller you have pin ccw and pin cw , i think i have those correct but im still looking for the steps and what not , any help would be appreciated.
    Jan 2006
    357
    In mach3 you can go to the settings page/tab, just above the reset button there is a button called click on it. Pick an axis to calibrate type in how far you want to move then put in how far it moved, do it several times for each axis and mach3 will figure it out for you
    Dec 2011
    8
    Tried that around 90 times and can get things better but still the motors are jerky and allmost seem to growl at you when you send a jog to them. It has something to do with the pulses im sure and the acceleration but i cant seem to find any documentation that would tell me close to where i need to be.
  1. warthog and oldschool dos software issues
    By new2ya in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-13-2012, 02:21 AM
  2. First real problem with older warthog.
    By malutki in forum Camaster
    Last Post: 10-29-2009, 01:24 PM
  3. Official Warthog support
    By CNChelper in forum News Announcements
    Last Post: 10-29-2009, 01:54 AM
  4. WartHog need repair
    By jteister in forum Community Club House
    Last Post: 11-06-2008, 01:35 AM
  5. Ever used a Warthog?
    By cncnoob in forum Commercial CNC Wood Routers
    Last Post: 01-31-2007, 01:50 PM
