587,773 active members*
3,400 visitors online*
Thread: Fanuc 10M
Page 2 of 3 123
Results 21 to 40 of 45
  1. #21
    AMTB Guest
    Quote Originally Posted by underthetire View Post
    I've put in many old machines, from mori to Makinos. Never did I need another transformer. Your in over your head. Call someone before you hurt yourself or cost yourself thousands on electronic repair.
    this is old machine.
    what do you doing to do if one shop has power supply 480V, another shop 240V and another 208V?
    Fanuc use 200V and for axis Fanuc use 185V
    Can you avoid transformer?
  2. #22
    Feb 2009
    6028
    Fanuc uses 200 v at 50hz. 208-230 is totally fine at 60hz. 480 volts is using a main transformer to knock it down to 220 or so. Some had machine transformers for this, others do not. Either way, the machine gets 220 volts +/- 10%.
  3. #23
    AMTB Guest
    Do you have e-mail ?
    i can e-mail PDF file from Fanuc, that show wiring of transformer.
  4. #24
    Mar 2012
    19
    i have old machine too, with the 0 m fanuc control.there are so many trnasformer insideain panel.better u should check one by one connection.but i think thats a good idea, if u upload the wiring diagram in this forum.maybe thats will make easier to solve your problem
  5. #25
    AMTB Guest
    FANUC 10M Soft Limit
    Hi
    I found problem with my FANUC 10M control in the way - 1. i start machine and switch to HOME and start process.
    Axis start moving to the switch but 2 or 3 inch before switch touch stop i getting ALARM - Soft limit .
    My question is why Soft Limit activated before Axis actually limit switch actually touch Stop?
    How i can solve this problem?
    Thank you
    Aram
  6. #26
    Aug 2008
    153
    Fanuc 10 Soft Limit disable
    Aram,
    To disable the soft limits temporarily on a 10M:
    1) Power on the control while holding the Period and Minus keys simultaneously.
    2) This invokes the IPL menu, which gives several choices. Select choice 4.
    3) Answer the question, soft limits yes or no.
    4) Exit IPL mode by pressing 99 and Input.
    Now, there will be NO soft limits. BE CAREFUL.
    When you get it to home properly, move all of the axes off home slightly and power down. This will allow soft limits to work again. Power up and everything will home normally.
    Warren
    Uptime Electronics, Inc.
  7. #27
    AMTB Guest
    Hi
    Thanks for the help
    I trying to follow instruction but how to do that?
    I did that, and it is working.
    How i can -- select choice 4--?
    Type 4 and Input? Cursor down does not working ?
    How to --- answer the question--? Type Y and Input?
    that is easy and clear, i can do that
    Thank you Aram
  8. #28
    Aug 2008
    153
    Aram,
    Sorry for being vague -it's been a long time since I've done it.
    Yes, press the number 4 and input to get to the next question.
    I think the answer to the question is "Y" input.
    Just read everything slowly. The IPL menu has choices there that can erase a lot of data. If you get into a screen you don't know the answer to, just shut off the control.
    Warren
  9. #29
    AMTB Guest
    Hi
    After i 4 -Input , question show
    "Check soft OT at power ON?"
    What this means ?
    What is "OT" ?
    I am afraid to create more problem than i already have by trying push thisa or those.
    So, what should i do with - after --
    Aram
  10. #30
    Aug 2011
    2517
    that means Over Travel
    answer N to check OT limits
    then follow the instructions in post #26
  11. #31
    AMTB Guest
    Hi
    Thank you all for help. I did home machine.
    Now, how i can check through IPL is my SOFT limit now ON?
    Just want to be sure that safety is ON.
    To help to prevent trouble.
    Thank you
    Aram
  12. #32
    Aug 2011
    2517
    soft limit has nothing to do with safety.
    soft limit is the limit of the axis stroke.
    by powering machine off/on soft limit checking is automatically on.
  13. #33
    AMTB Guest
    Hi
    about steps
    I did step 1.
    i did step 2.
    than i press 6 and normal positioning screen show up and i did HOME machine with no problem.
    Than i tuen OFF controller and home machine again and machine work good.
    I did not use step 4 --4) Exit IPL mode by pressing 99 and Input.
    is this a problem ?
    It just work out without step 4.
    what should i do?
    thanks
    Aram
  14. #34
    Aug 2011
    2517
    just run the machine it's working fine as-is.
  15. #35
    AMTB Guest
    Fanuc 10M -light bulb?
    Hi
    I want to change light bulb for FANUC controller 10M,
    when home axis X light bulb is ON, same for axis Y and Z.
    Where i can find such small light bulb?
    I think it is 12V light bulb.
    Thank you
    Aram
  16. #36
    Sep 2010
    1230
    Quote Originally Posted by AMTB View Post
    Hi
    Thank you
    Aram
    Hi Aram,
    Are you sure its a light bulb? LED's are generally used for this application and are available at most good electronic supply shops. If it is a LED, these seldom fail. More times than not, their apparent failure is in fact a faulty chip on the interface I/O board. However, you state in your post that all three axes inductors turn on. If so, why do you need to change any, or is that a mistake in the post?
    Regards,
    Bill
  17. #37
    AMTB Guest
    FANUC 10M axixX reverse
    Hi
    I have problem with my X axis.
    After i home all axis X Y Z, and start jog axis away from HOME switch, X axis must be jog in positive direction to move away from HOME switch.
    Axis Y and Z need to be jog in negative direction to move away from HOME switch.
    i know it is rare condition/problem.
    What should i do in controller to fix this problem and make X axis same as a Y and Z axis?
    Thank you
    aram
  18. #38
    AMTB Guest
    Fanuc 10m
    I need help to understand what i did today.
    I start replacing light on Fanuc 10M that show that axis X Y Z at home.
    There are small panel that i unscrew to get to light bulb ( yes it is not LED it is 1987 ) That panel has resisters and when they touch screwdriver i got many Alarms like Spindle Alarn, Air Pressure Alarn,
    Also i look on drivers and on driver for axis X Y Z i can not see small light.
    Is there some reset things to push?
    thank you
    Aram
  19. #39
    AMTB Guest
    Fanuc 10M -M6 code
    Hello
    i have a problem with M6 tool change.
    this machine did use m6 and i did see that before i got it. after i moved machine m6 -cycle on -nothing is happen.
    i did use MDI for
    M11 and M12 =magazine CW and CCW and it works
    M13 and M14 = spindle CW and CCW
    M19 spindle oriented stop works also
    M21 M22 magazine right -left
    M23 M24 magazine UP Down
    M25 M26 tool clamp and unclamp
    everything works by them self but M6 that use all above code does not
    Where is problem?
    thank you
    Aram
  20. #40
    Mar 2008
    150
    Do you stand in tool change reference position?
    G0G91G28Z0, or it also could be in a second ref. position =
    G0G91G30Z0
    Kitamura Mycenter 1 -83 with Fanuc 3M-C and Mycenter 1B -85 with 10M control.
    Yes, they are old..... but i still like them!
Page 2 of 3 123
  1. GE Fanuc & FANUC proprietary posts
    By cncadmin in forum Fanuc
    Last Post: 01-12-2022, 07:33 PM
  2. Fanuc 5S servo tuning on Fanuc 15TF
    By rai in forum Fanuc
    Last Post: 02-05-2012, 11:38 PM
  3. Replies: 5
    Last Post: 03-09-2011, 04:11 PM
  4. Fanuc & GE Fanuc Repairs
    By RRL in forum News Announcements
    Last Post: 10-01-2008, 06:42 PM
