587,789 active members*
4,408 visitors online*
Results 1 to 13 of 13
    Oct 2009
    67
    Duality lathe question
    I was thinking of getting one...
    Does anyone think it can cut 316L Stainless? Is anyone cutting stainless with it.
    Im looking for a CNC lathe and dont have a ton of space or money.
    TIA
    Kyle
    Oct 2011
    121
    Quote Originally Posted by HLF Ordnance View Post
    Why wouldn't it be able to?
    Oct 2008
    103
    I discussed this with Bob at Tormach several years ago. He had said that it would turn stainless with light cuts. My question was "can it part 304?". I sent him a 3/4" round 304 sample and he tested it. His reply was that it wasn't recommended.
    If you do need to just turn it, I'd go with 303 stainless if you can. I turn this on my large lathes, cuts/parts great.
    Oct 2009
    67
    Thanks WOG!!!
    I have a request from my father-in-law (which means no profit, thus I want to do it at home on my 1100) to make some instruments for his dental surgeries.
    It needs to be 316L because some of them come to a .02" blunt tip off of a 10deg taper that will be put under shock. I know 316 is a pain to machine but I think 304 might bend???
    Might put a collet holder in the table and machine it like that. Or put the work piece in the spindle and get the TOSA tool vert lathe kit.
    Kyle
    Nov 2006
    134
    As a duality owner, I strongly discourage planning to use it for anything except soft metals with small diameters. The spindle motor is severely underpowered for open-loop CNC control, and it stalls easily and often. I cut over a hundred 1/2" diameter W-1 steel parts for one project, and although I eventually got them all made within tolerance, it was an experience I plan to never repeat.
    Oct 2011
    121
    Kyle
    All u need is a lathe cutting tool if you are able to mount the work in the spindle. I have cut 316L this way with so much ease, as long as you have the right kind of insert.
    Oct 2009
    67
    thanks guys, I am going to put the work in the spindle. Duality lathe is cool, but I already have a small chinese lathe. haha
    Dec 2010
    1230
    Is the motor the only concern in these duality lathes? Its all I see when someone mentions the duality. Is it not possible to throw a bigger motor on? Perhaps a KB controller too? Is the speed signal 0-10 vdc? I just picture a KBIC controller and a 3/4-1hp motor and keep the cuts reasonable.
    Or is it just that much easier (obviously cheaper) to mount in the spindle and learn to program that way?
    I'm asking because I have parts that are 3" round by 8" long 1018 that need about 2/3 of the metal removed (picture a dumbell). Takes FOREVER on a manual lathe and I would love to be able to do it on a duality under CNC. My impending purchase is getting closer and wondering if it is modify-able as I would throw it on the ever increasing total.
    I'm sure its smarter to just cnc a 12x36, but just wondering as I've seen these same concerns over and over and to the completely ignorant (never seen one in person) it seems like a fairly straight forward fix... SEEMS and IGNORANT likely being key words here.
    Oct 2011
    121
    3" x 8" long- I would rather do turn milling with the 4th axis (if you have one)
    Oct 2008
    103
    If you don't have to use 1018, switch to 12L14 and you'll save a lot of time whichever method you choose.
    Nov 2006
    134
    I think it would be an impressive bit of engineering to tweak the duality into something that you'd want to use for cutting a 3"x8" bit of 1018.
    You'd be much, much better off using a modified lathe or else building a beefier version of the 4th-axis mill-turn unit like what this guy has been making:
    [ame="http://www.youtube.com/watch?v=b2-Kdud7eiA"]Simpson36's mill-turn 4th axis.[/ame]
    Personally, I'm waiting to see what the Tormach lathe looks like, and then I'll either get that or else a low-end Haas. When I get a big enough shop, I'll eventually get a real manual lathe to replace the duality entirely. As it is, I only use it in manual mode now, so it's no different than all the other mini-lathes out there.
    Dec 2010
    1230
    That indexer set up is really neat! The cost if the duality plus mods comes too close to microkinetics conversion kit to be worth it. I love the idea of adding a turret later too. Only major downside is having to use their software when I already know mach and mastercam :-/ Guess I'll cross that bridge when I get there and just keep looking forward too the tormach lathe.
    Oct 2009
    67
    wow thats a sweet setup!!!
    Any recommendations on inserts for 316?
  1. for those looking for an alternative to the duality lathe...
    By Doubleoh9 in forum Tormach Personal CNC Mill
    Last Post: 01-29-2012, 11:14 PM
  2. Duality Lathe or vertical lathe with 1100?
    By Gundawg in forum Tormach Personal CNC Mill
    Last Post: 10-04-2011, 11:11 PM
  3. Anyone have a Duality Lathe they want to part with?
    By dbrija in forum Tormach Personal CNC Mill
    Last Post: 02-08-2011, 06:21 PM
  4. Using the Duality Lathe.
    By Willyb in forum Tormach Personal CNC Mill
    Last Post: 05-12-2009, 09:55 PM
  5. Duality lathe advice
    By Attila Bertok in forum Tormach Personal CNC Mill
    Last Post: 01-28-2009, 02:41 AM
