I have a Problem of laser power which is not the same on the whole table, it can cut with the same power till the center of the table but when going far to the extreme right of the table at the top or at the bottom it can not cut i have checked the table it is weel leveled .
what do you suggest ?
the table is 900mm*600mm and the laser tube is Reci 80w used for only 2 hours.
