587,699 active members*
3,562 visitors online*
Page 12 of 22 21011121314
Results 221 to 240 of 421
  1. #221
    Apr 2005
    419
    Quote Originally Posted by woffler View Post
    I have others on a mill for axis drives XYZ and A with harmonic drive and chuck. Hopfully the speed will be as talked about because i sure could use it on the A Axis and lathe drive.:wee:
    Yeah, if we start seeing dmm maintain its awesome price/performance ratio into the larger servos there is the potential to do some really cool things.
  2. #222
    Dec 2003
    24220
    Quote Originally Posted by 691175002 View Post
    It looks like their new offerings might be more well suited. 5000RPM with 7.2Nm peak stall is a pretty big improvement over their 48V drive.
    The Continuous stall torque should be used as the design criteria.
    The 7.2Nm peak stall torque is a moot value as far as operation is concerned, it is a value you should never reach as this usually is the destruction point of the motor, particularly if it is reached for any length of time.
    And if you have reached it, it usually means the motor is being driven out of control.
    IOW a system that allows the motor to reach this value has essentially lost control of the motor.
    Al.
    Albert E.
  3. #223
    Jan 2005
    15362
    Al_The_Man
    I would be curious to know what the pole count is of the DMM servo's?
    Al the motor in the post is 4 pair or 8pole
    Mactec54
  4. #224
    Jan 2005
    15362
    For those that are waiting for the new Drive, The Drive it's self is complete, The Injection molded Case is what has been the hold up, But is very close to being finished also, I also have the PDF Manual but is not officially complete
    This New AC Servo Drive is powered by 120VAC or 220VAC Input, no other low voltage DC input is needed
    Mactec54
  5. #225
    Oct 2010
    Thanks Mactec54, I can't wait to get a hold of the data.
  6. #226
    Jan 2005
    15362
    iknowyoudo
    You can PM me with your email & I will send you the PDF for the Drive
    Mactec54
  7. #227
    Oct 2010
    Mactec54,
    You rock! Thanks. PM sent.
  8. #228
    Jul 2006
    1256
    Why does pole count matter?
    Mactec,you could PM & PDF me the drive please
    Larry
    L GALILEO THE EPOXY SURFACE PLATE IS FLAT
  9. #229
    Oct 2010
    I believe more poles = higher torque. Please correct me if I'm wrong. I'm much better at running cnc than electrical. I might be giving myself a lot more credit than I deserve. lol.
  10. #230
    Jun 2007
    3891
    Quote Originally Posted by iknowyoudo View Post
    more poles makes for smoother movement at low speeds. something good in a servo which primarily runs at lower speeds and needs high accuracy of motion. so its not really more torque, but likely better use of it.
    a spindle tend to use a low poll motor, since it just spins up to a high speed and stays there.
  11. #231
    Sep 2005
    1195
    mactec,
    How about the price? This is most important.
  12. #232
    Dec 2003
    24220
    The higher pole count does make for smoother operation, but at a cost of RPM, there is one electrical revolution for every mechanical revolution for each pole pair, so for an 8 pole motor (4 pole pairs) there is 4 electrical revolutions for every mechanical.
    For a 8 pole motor to reach the same rpm of a 2 pole, the frequency would have to increase x4.
    Al.
    Albert E.
  13. #233
    Jul 2006
    1256
    Al_the_man,What is your opinion on a servo system with DMM servos,the new 110/220 3 phase drives and KFlop and or Kanalog.It appears to be an inexpencive way to close the loop and operate at higher speeds than Mach3
  14. #234
    Apr 2005
    419
    Quote Originally Posted by lgalla View Post
    This is exactly what I am planning to do on my next machine this summer.
    The only real drawback is that the DMM system uses absolute encoders which means that you do not have the option of closing the loop on the KFlop without adding incremental encoders. Closing the loop on the KFlop could potentially make a difference since it has far more sophisticated ways of turning the control loop.
    I am actually considering using DMM servos + glass slides. By feeding the linear encoder to the KFlop it can compensate for backlash and innacuracies in the ballscrews.
    For ~150$ an axis it seems worth a shot.
  15. #235
    Jan 2005
    15362
    691175002
    The New Drive can use Absolute & Incremental Encoders, There is a separate plug on the drive A/A-, B/B-,Z/Z- position signal as the form of Incremental encoder, line number is scalable from 500 to 2048.
    Mactec54
  16. #236
    Apr 2005
    419
    691175002
    The New Drive can use absolute & Incremental Encoders, There is a separate plug on the drive A/A-, B/B-,Z/Z- position signal as the form of incremental encoder, line number is scalable from 500 to 2048.
    DMM Servos use an SPI interface which looks pretty complicated.
  17. #237
    Jan 2005
    15362
    lgalla
    A smoothstepper will give you the highspeeds to
    PDF in the mail
    Mactec54
  18. #238
    Dec 2003
    24220
    I don't have any experience with DMM equipment.
    If I were to go with Kflop & Kanalog I would use BLDC motors and simpler torque mode amplifiers such as Advanced Motion or Aerotech with ±10v analogue control, the encoders would close the PID loop to Kanalog rather than the drive.
    Another advantage where the loop is closed in the controller opens up the possibility of axis gearing, one off another.
    This would emulate the Galil motion systems I presently use this way.
    Al.
    Albert E.
  19. #239
    Sep 2005
    1195
    mactec54,
    So we can use smoothstepper. Have you tried compatibility with eding usb cnc, will you try them while in the beginning of new drive? It is good, beside using mach3, we can use another software that maybe better or bad. eding usb cnc seems good but I have not much info. I am using GD VSD e 160 dual drive and Gecko 320 w/PMDX 126, in the future I will use DMM for at least 1 of my machine.
  20. #240
    Jan 2005
    15362
    asuratman
    Dmm has been using the Plant-CNC with there system, I like the look of the Eding cnc control to but have not used it, Smoothstepper works well with the Dmm Drives plus any ±10v analogue control will work well to
    Mactec54
  1. Propriatary AC servos into universal AC servos with an encoder swap?
    By SwampDonkey in forum Servo Motors / Drives
    Last Post: 05-10-2013, 07:22 PM
  2. Servos for 604
    By excello in forum Uncategorised MetalWorking Machines
    Last Post: 03-16-2012, 08:21 PM
  3. EMC and servos
    By RP Designs in forum LinuxCNC (formerly EMC2)
    Last Post: 05-08-2009, 05:06 AM
  4. AB servos
    By macgeek10 in forum CNC Machine Related Electronics
    Last Post: 05-28-2006, 05:05 AM
  5. Servos
    By cncadmin in forum Mach Software (ArtSoft software)
    Last Post: 07-17-2004, 07:19 PM
