587,083 active members*
2,675 visitors online*
IndustryArena Forum > CAM Software > CamBam > cant install .net framwork for cambam
Results 1 to 10 of 10
    Dec 2010
    ok so I got cambam and my pc doesn't have .net framework I got windows xp and when I try to install .net framework 3.5 it says I need 3.0 so I downloaded 3.0 and it says I need 2.0 so I downloaded 2.0 and now it says it cant install it says corrupt or not enough memory can someone tell me what I need to do please
    4826
    What I had to do one time, was uninstall the later versions of the .net framework. Then it would let me install the 2.0 version and add the others in, in proper sequence.
    Dec 2010
    it has .net 1.1 but i cant get 2.0 to install
    Feb 2005
    521
    I am sorry to hear you are having problems with the .Net install.
    As HuFlungDung recommends, I would first try uninstalling any instances of the .Net framework from control panel.
    Then install V3.1 of the windows installer available here...
    Windows Installer 3.1 v2 (3.1.4000.2435) is available
    The .Net framework 3.5 needs the V3.1 installer to work but shouldn't need any previous .Net frameworks versions installed.
    I would then try the 3.5 installer again, but scroll down the page and download the link marked '.NET Framework 3.5 Service Pack 1 (Full Package)'
    Download details: Microsoft .NET Framework 3.5 Service Pack 1
    Best of luck!
    Andy
    www.cambam.co.uk
    Feb 2012
    23
    I see this is an older thread, but I had this same problem.
    I used "Windows Update" to correctly install the .NET framework. It took several iterations and restarts, but eventually got it to take. Of course, this assumes that you have Windows Update configured.
    To launch Windows Update, it was: Start->All Programs->Windows Update.
    Jan 2012
    60
    The worst thing about .Net is that the various numbers are NOT true "Version Numbers", in that higher numbers do not include or update the functionality of the "Older" versions. You can end up having five different .Net packages installed on your computer and need all of them for different pieces of Software.
    Thank you Microsoft for keeping Computing simple!
    Feb 2005
    521
    It can be reasonably painless if you stick to this...
    For an XP box, just install the .NET 3.5 framework....
    Download: .NET Framework 3.5 - Microsoft Download Center - Download Details
    This will work for .Net applications written for all older framework versions up to 3.5.
    (4.0 on it's own won't work for early version apps :tired: )
    For Vista and later, .NET framework 3.0 or later should be installed by default.
    Then just let windows update install the later framework versions as they arrive.
    Quote Originally Posted by Mauser View Post
    www.cambam.co.uk
    Jan 2012
    60
    Not quite true, that doesn't include the previous versions of .net, it just includes the service pack updates for them.
    Apr 2006
    40
    I just wanted to say that I am having the same problem. The .net 3.5 installer fails. I was able to install the 4.0 one, but that doesn't help here.
    Apr 2006
    40
    I reinstalled xp and was able to install.
  1. CamBam
    By ckjk616 in forum CamBam
    Last Post: 10-28-2010, 11:19 AM
  2. CamBam 0.9.8
    By blowlamp in forum CamBam
    Last Post: 10-12-2010, 10:43 AM
  3. what is CamBam?
    By cncadmin in forum CamBam
    Last Post: 05-02-2009, 01:41 AM
  4. Need Help With CamBAM
    By Ponchibego in forum CamBam
    Last Post: 08-01-2008, 03:49 AM
  5. Will CAMBAM run in Win 98 ?
    By epineh in forum CamBam
    Last Post: 08-03-2007, 06:50 AM
