587,917 active members*
3,437 visitors online*
IndustryArena Forum > CAM Software > Visual Mill > Selecting sketches from a linear pattern
Results 1 to 8 of 8
    Jan 2007
    83
    I am using VM for SW. I designed a simple pattern for a Tee nut. It consists of a through hole, two counter-bores and 4 drilled holes for the tangs. I then repeated this structure using the linear pattern feature in Solidworks. Now when I want to select all of the similar holes in CAM to generate gcode, I can only select the original sketches, not the repeated ones. How do I do this?
    Dec 2010
    634
    I think what you want to do is use the "select curves as regions" and then select the sketch with the repeating pattern. You'll have a design tree just to the right of the dialogue box and you'll have to expand it to show the sketches within the feature. If your original is on the same sketch, it is also selected.
    If there's anything in there that's extraneous to the operation you can delete it from the list.
    There's an additional advantage to using select curves as regions because the link is maintained if you update the feature. If you select flat area features you have to re-select in VM each time you update the feature.
    -Andy B.
    http://www.birkonium.com CNC for Luthiers and Industry http://banduramaker.blogspot.com
    Jan 2007
    83
    Andy-
    Thanks for your comment. The operation I am trying to set up is a drilling operation. My choices are 1-drill poiints/circles or 2-holes in a flat area. I have tried both without much success.
    Bruce
    Dec 2010
    634
    I just tried using "select drill points/circles" and it worked fine. The sketch has two holes that I repeated 4 times total. I just selected it, hit generate and boom.
    Attached Thumbnails Attached Thumbnails Screen Shot 2012-03-23 at 6.35.17 PM.jpg   Screen Shot 2012-03-23 at 6.35.03 PM.jpg
    -Andy B.
    Jan 2007
    83
    Andy-
    Are you using VM or VM for SW?
    Bruce
    Dec 2010
    634
    VM for SW - see the screen shots above.
    -Andy B.
    Jan 2007
    83
    Andy-
    Thanks for your efforts - it is nice to have someone make suggestions. I think the difference between my case and yours is this - the holes in question are all inside a shallow countersink for the flange of the Tee nut. There are 9 of these structures spaced across the workpiece. Each countersink has 4 drilled holes. So there are 36 holes of this size in all. But they don't share a common surface. I will post an image of the part.
    Bruce
    Attached Files Attached Files
    Dec 2010
    634
    OK I see what's going on now. I didn't really read the part where you're patterning a "feature", not a sketch element.
    I made a quickie like what you have and tried it and got the same thing - VM doesn't seem to want to deal with the linear pattern of features. VM should be told about this. I could get it to work by using the flat area thing though. You just have to click on each pocket, hit ok and the use select again.
    But for your current issue, I'd just re-draw it patterning the holes in a sketch rather than as a feature. Probably the simplest way to do it.
    -Andy B.
  1. pattern
    By wizard200097 in forum PowerMILL
    Last Post: 05-26-2012, 03:07 PM
  2. Constraining sketches.
    By Stampede in forum Autodesk
    Last Post: 01-10-2012, 07:17 AM
  3. Linear Feature Pattern - Chamfer?
    By tikka308 in forum Uncategorised CAD Discussion
    Last Post: 11-09-2011, 10:31 PM
  4. Pattern
    By aallen in forum G-Code Programing
    Last Post: 03-25-2011, 03:29 AM
  5. Derived Sketches - How does one......
    By Aquatic in forum Solidworks
    Last Post: 03-13-2011, 09:47 PM
