Originally Posted by
Mauser
Wow, those are some great replies!
harryn: Hmm, I was thinking "Architectural" square tube for the LaserBeast gantry, with 20 mm rail on either bottom corner and the mirror/lens suspended directly underneath, and some diagonal arms going back to the X end of things to keep it square. That sort of stuff is usually pretty straight and stiff, since it's designed to be pretty. Not as hard as some aluminum, but between the size and the light load, it should be okay.
The problem with 8020 is that it actually isn't flat on the sides, it's designed to spring a little where you bolt it. But I've seen the rail you're talking about, and I might consider it. I need to check some of the local parts suppliers and see what's available.
(gotta finish these drawings!)
Ger21: I've been wrestling with how to do the drive from both sides. It would either be slaving another motor, or getting a drive rod all the way across the gantry and running long belts to drive the ServoDrive, which would introduce some of the slack the ServoDrive is supposed to eliminate.
With a machine this long, running a drive rod under the table means less support under the table and possible bowing with the legs all the way at the end, a 9-10' span. I was figuring a cable system is the way to get force from one side of the gantry to the other.
There's no way to win, really. A drive rod could twist or whip, cables can stretch, and dual motors can get out of sync. One thing the dual gantry idea was supposed to help with was to make the connection between the two sides (is there a good name for the X-axis part?) stiff enough that it would also prevent racking.
Re the Z-axis: I hadn't thought about the lifting portion being an issue. With a single pitch screw, backdriving from gravity isn't such a problem, but speed is. Multi-start acme screws give better speed, but they can be backdriven. Has anyone tried using springs to help support the carrier? Heck, it could even eliminate backlash by biasing the carrier up if they were strong enough....
Anyway, most kits seem to be 3 or 4 of the same motor. So perhaps that's how I should go.
harryn again: Not really. With stretchy cloth like Spandex, evening out the tension that's already built into the roll is one of the issues even with hand cutting it. It's one of the reasons I was concerned about honeycomb tabletops, because the chance of a snag while sliding the cloth around could ruin the part.
As for the physical plant, moving tables is the least of T's worries. I've seen her in a whole lot of different warehouse spaces. (What is it with Seattle Commercial landlords? They're NUTS! The latest one is trying to rip her off on Utilities, and she just got there! She may move again before i build this.). She's got probably half a dozen cutting tables at least as big as the machine will be, and about as many industrial sewing machines. I've helped move them. That pizza was EARNED.
But that does make a point about making it easier to take apart and move.
louieatienza: Point taken about differing drive power requirements. The G540 might be a bit much for a 2-axis machine. Maybe some other breakout board and two individual drivers. Any suggestions?
Ger21 again. Point made. Speed is the object on the laser. Especially if she can only cut one or two layers at a time. She usually does six by hand, and for really big stack-ups, she has a device that puts a giant motor oscillating on top of a foot long blade that ends in a shoe that slides under the fabric. It's so sharp though that she's scared of it (and rightly so, it makes ScarySharp look Bronze Age).
As for routers, I was going to just start with one of my PC 690's and a SuperPID.
I'm getting a fat tax return this year. I'm going to run out of excuses soon. :-)
