587,492 active members*
3,627 visitors online*
IndustryArena Forum > MetalWorking Machines > Hyundai Kia > KIA TURN 31 DNC PARAMETER
Results 1 to 4 of 4
    Sep 2010
    86
    Hi to all,
    Im working on a cnc lathe Kia Turn 31 with a Fanuc OT control.
    The machine is having a Tape mode. Can someone who did use that mchine helps me with the correct dnc parameters( baud, parity, even......) . I try to send or receive a program ,but nothing works.
    Thanks in advance.
    Mar 2012
    Parameters screen
    Par 000 ISO = 1 For FANUC Device.
    Par 20 I/O = 1
    Make sure that par 0100 bit 3, NCR =1
    Par. 111= 1000001
    Par. 112= device num.- 0 (rs232)
    Par. 113 baudrate.- 10=4800,11=9600
    MAke sure of these parametres are OK..but the sftware you are using in you PC must has the same baudrate configuration,bit, etc and the port of your PC as welll.I hope this helps...
    Oct 2009
    297
    Quote Originally Posted by mousongie View Post
    Hi to all,
    Thanks in advance.
    If the control is 0T then check parameters (X= don´t care)
    2= XXXXXXX1
    38=X1XXXXXX
    552= 10 (10 means 4800)
    Can you upload and download programs?
    If you change to "tape" mode do you see any diagnostic change?
    It is important to see if the control is a 0T (A, B, C) or a 0iT because the parameters are different and the diagnostics are different. If it is a 0iT then use the parameters shown by Sergio.
    Regards
    Alex
    Sep 2010
    86
    Hello guys!
    Thanks for your quick intervention. The control is OT, and so far i cant either receive or send a program to the computer or vice versa. I will try the above settings tomorrow and i will let you know the outcome. Big thanks to Sergiogc and alexfanuc .
  1. Parameter to turn off Spindle at M00
    By aadonline in forum Fanuc
    Last Post: 02-04-2012, 08:53 AM
  2. PARAMETER MAZAK SLANT TURN 30 WITH MAZATROL T1
    By tonny2105 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-06-2010, 09:30 PM
  3. Newbi Help please Parameter List slant turn 30
    By TOBYC in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-24-2010, 10:03 AM
  4. Cin Turn turn/mill
    By Robert Timby in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-25-2007, 02:12 AM
