587,089 active members*
3,024 visitors online*
Page 6 of 6 456
Results 101 to 113 of 113
  1. #101
    Feb 2012
    26
    Hi Bill,
    first off, you might want to think about adding a donate button to you signature!4 years later and there are people still interested in your work.
    You got me to join another forum just to ask you a question. Pretty simple one it should be:
    Do I need visual studio to get your program to install? I keep getting:
    unable to register the dll ocx regsvr32 failed with exit code 0x4
    on both my computers.
    looking forward to your response.
    Regards
    George
  2. #102
    Aug 2008
    573
    Hi George,
    The program is written in VB5, so you should not need VS at all.
    It was designed for Windows 95. I have not tried it on Vista or Win7, so that may be the problem (can you install on a VM or as XP?).
    the install script ireads:
    Source: "d:\My Documents\VB5 projects\Logger\Vernier.exe"; DestDir: "{app}"; Flags: ignoreversion
    Source: "e:\VB\System Files\MSVBVM50.dll"; DestDir: "{sys}"; Flags: onlyifdoesntexist uninsneveruninstall
    Source: "e:\VB\System Files\OleAut32.dll"; DestDir: "{sys}"; Flags: onlyifdoesntexist sharedfile regserver
    Source: "e:\VB\System Files\OlePro32.dll"; DestDir: "{sys}"; Flags: sharedfile regserver
    Source: "e:\VB\System Files\AsycFilt.dll"; DestDir: "{sys}"; Flags: sharedfile
    ;Source: "e:\VB\System Files\Ctl3d32.dll"; DestDir: "{sys}"; Flags: sharedfile
    Source: "e:\VB\System Files\StdOle2.tlb"; DestDir: "{sys}"; Flags: sharedfile
    Source: "e:\VB\System Files\MSCOMM32.OCX"; DestDir: "{sys}"; Flags: sharedfile regserver
    Source: "e:\VB\System Files\SCRRUN.DLL"; DestDir: "{sys}"; Flags: sharedfile
    Source: "e:\VB\System Files\comcat v471\Comcat.dll"; DestDir: "{sys}"; Flags: sharedfile regserver
    so there are only 4 files that require regserver.
    4 years? I started this in 2005! that's the problem!
    There are new scales out now that do not work with the PIC code (so be warned) At some point (way in the future), when I get one of the newer 21 bit devices I'll add it to the PIC.
    Meanwhile, I get people like aadityadengle waving bs flags at me, because they cant get it working!
    Is does work with the right scales:
    [ame="http://www.youtube.com/watch?v=7R-qcTCTcxk"]PIC based DRO - YouTube[/ame]
    Bill
  3. #103
    Jul 2011
    Question
    Quote Originally Posted by BillTodd View Post
    IT DID NOT WORKED FOR ME. BUT STILL WORKING ON IT.
  4. #104
    Aug 2008
    573
    Quote Originally Posted by aadityadengle View Post
    My guess is that you have igaging type scales (or yet another chinese type that I have not seen)
    The Igaging scales are quite different and in some ways better, but they will require a different PIC code:
    21 Bit Protocol Scales | shumatech.com
    (BTW A big thankyou to Shumatech for making their research public :cheers:
    Bill
  5. #105
    Feb 2012
    26
    Hi Bill,
    thanks for the answer. I am trying to install it in windows XP. It is apparently trying to register inpout32.dll into the Regserver. will investigate and write back.
  6. #106
    Aug 2008
    573
    Quote Originally Posted by komatias View Post
    Hi Bill,
    Ah! I think you have the wrong version. The inpout.dll is only required on my POS board. (not sure why it wont install though)
    Give me a day or two and I'll compile a different version
    Bill
    Bill
  7. #107
    Aug 2008
    573
    OK this is a versio without the inpout.dll so should install OK (fingers crossed because I have not got a virgin machine to try it on)
    Bill
    Attached Files Attached Files
    Bill
  8. #108
    Feb 2012
    26
    Sorted! Thanks Bill
  9. #109
    Jul 2011
    @Bill
    Can we have an interface with pc for an incremental encoder which gives RS422 differential quadrature output?
    more details about the encoder as attachment
  10. #110
    Aug 2008
    573
    @Bill
    I'm afraid I don't have the time to work on this ATM I doubt the little PICs I'm currently using would be able to keep up with the scales (and hence lose counts) but it could be done fairly easily using the PICDSP chips, as they have quadrature hardware.
    One alternative you could try is EMC2 (for linux) I believe you can set this up using the printer port as input
    Bill
    Bill
  11. #111
    Jan 2014
    3
    DRO Design discrepancies.
    Reposted to correct forum - apologies.
    I was looking with great interest at Bill Todd's DRO designs, and I really want to build this one - I am quite at home with electronic assembly and PCB manufacture - but although an impressive amount of work has obviously gone into the design, the information downloaded appears to be fragmented and inconsistent, therefore I am having problems verifying schematic to PCB layout.
    Having downloaded the Zip package for Version 1.2.05, I found the PCB layout PDF file, but there was no schematic. I downloaded the schematic separately from the forum, but one does not verify with the other. The PCB layout has numbered components and nets given, the schematic has no numbering - just question marks. I have tried tracing by eye, but there are several discrepancies. eg pin 7 of the DB9 goes nowhere on the schematic, but is connected on the PCB; there are 2 diode cathodes to 3.5V on the PCB, but only 1 on the schematic; there are 2 resistors to DB9 pin 4 on the PCB but only 1 shown on the schematic. I gave up at this point as clearly the schematic that I have is not the one that the PCB was netlisted and routed from.
    Is there a schematic and PCB layout that are a matching set somewhere, or alternatively a definitive schematic somewhere that I can confidently use to netlist and route my own PCB from?
    I really don't want to spoil a good project or waste time and money by going off half cock, so I trust some kind soul will be able to point me in the right direction.
    Thanks.
  12. #112
    Oct 2010
    93
    Why don't you send a PM (private message) to Bill?
    I always believe in getting information directly form the "horses mouth".... He's friendly, helpful and doesn't bite
    Joe in Aus
  13. #113
    Aug 2008
    573
    Re: PIC based DRO
    Hi All
    Anyone wishing to build this project should bare in mind that I designed this some years ago for use with the 1.5V (positive frame) callipers that were around at the time. Modern callipers and scales have moved to a 3v (positive or floating frame) that require a different ground and power arrangement.
    I've pretty much given up developing the PC application as there is a better Andriod tablet based app being developed by Yuriy
    (Yuriy's Toys: Android DRO Project)
    I will at some stage update the PIC code to work with Yuriy's DRO but I have little time these days (personal reasons) so it could be a while before i get a 'round tuit'
    Regards
    Bill Todd
    Bill
Page 6 of 6 456
  1. Is water based
    By cncadmin in forum Safety Zone
    Last Post: 10-19-2022, 05:10 PM
  2. Need help with CNC UK based
    By ciscoe in forum European Club House
    Last Post: 07-21-2008, 12:03 PM
  3. Pic based Oscilloscope
    By thegimpster in forum PIC Programing / Design
    Last Post: 01-25-2008, 07:48 PM
  4. PC Based Controls
    By zimbricd in forum News Announcements
    Last Post: 12-12-2007, 09:38 PM
  5. dos based cnc software
    By flyingmike in forum Computers / Desktops / Networking
    Last Post: 11-25-2005, 08:29 PM
