Bob1112
At 3:49 in the 2nd video (should not look like this), I noticed significant deflection to the left.
Had a similar problem and discovered that the tool was radiused on one side only and when mounted in the holder it cocked it slightly, causing it to wander. The tool was designed to be used at one end only. Of course I was using the wrong end.
Have also had this happen when the tool is not exactly perpendicular to the work.
John
