587,829 active members*
2,866 visitors online*
Results 1 to 5 of 5
    Apr 2004
    79
    Exclamation Spindle fluctuation issue
    Quote Originally Posted by Drew View Post
    Burgmaster Mill 6M Spindle issue
    6044-H007 model 3 AC spindle
    Sometimes the spindle acts up speeds up,slows down and even reverses for just an instance.
    Checked feedback and found sqr wave off a little on duty cycle. 35 to 40%
    Sine wave feed back looks good (.6v wave at 2.5 rms)
    I have pictures and video will add when i can.
    I have two servo units and have seen it on both and was wondering if it could be the motor?
    [ame="http://www.youtube.com/watch?v=hU2J2V6_LYo"]Burgmaster Mill 6M[/ame]
    If I had something important to say it would be here.
    Apr 2004
    79
    Could this be caused by line voltage being 246 rms?
    Jul 2010
    369
    Have you checked your spindle encoder & spindle drive control?
    Apr 2012
    After watching that video it sure looks like a feedback issue with the encoder or cable. Have you checked all the connections on the cable ? That type of problem is not likely in the motor.
    You could test the motor out of the system by applying 3 phase voltage directly to the motor and see if it runs smooth without issues. But still looks like feednack issue. Try another cable & or encoder.
    Feb 2009
    6028
    I've seen that once before, helping a friend. It was on a mori lathe with a 6 as well. It ended up being a built in sensor inside the spindle motor. It was a fanuc drive witha fuji motor. Cleaned, adjusted and it ran good. Ordered another sensor just in case.
  1. XV1000 Spindle Issue
    By ggundrum in forum Bridgeport / Hardinge Mills
    Last Post: 11-16-2011, 05:52 PM
  2. Bridgeport/Romi Speed fluctuation
    By Riverside192 in forum Bridgeport / Hardinge Mills
    Last Post: 12-02-2008, 06:18 AM
  3. X3 Spindle Issue?
    By chns in forum Benchtop Machines
    Last Post: 11-27-2008, 12:58 AM
  4. Bridgeport/Romi Speed fluctuation
    By Riverside192 in forum DNC Problems and Solutions
    Last Post: 10-13-2008, 06:38 PM
  5. Super X3 Spindle Issue
    By dafowfidy in forum Syil Products
    Last Post: 01-09-2008, 08:17 PM
