587,832 active members*
3,545 visitors online*
Results 1 to 1 of 1
    Apr 2003
    302
    1/4" to 10 mm thick steel plate
    I need 2 steel plates drilled, tapped and counter bored as shown in the drawing. The plate needs to be within 1/4" to 10mm thick +- .1mm and all dimensions need to be within +- .1mm. The material can be almost any carbon steel (please specify). I need this BEFORE christmas. I am in Florida.
    Attached Files Attached Files
  1. Cold-rolled steel plate, 13"x24", 1/2" thick.
    By Odin in forum Want To Buy...Need help!
    Last Post: 02-23-2010, 04:00 AM
  2. Simple 1/4" thick 6061 plate
    By Aaron92SE in forum Employment Opportunity
    Last Post: 05-16-2008, 10:47 PM
  3. Cutting thick steel plate
    By Woodenspoke in forum MetalWork Discussion
    Last Post: 07-12-2007, 05:58 AM
