587,300 active members*
3,252 visitors online*
IndustryArena Forum > Mechanical Engineering > T-Slot CNC building > Aluminum T-Slot Build Using Misumi Extrusion
Results 1 to 20 of 56
Threaded View
    Apr 2010
    I debated in which forum to post this, but since Misumi doesn't seem to get a lot of discussion, it seemed warranted to put a build log here to show what their products look like and what the US company can do when ordering almost exclusively over the web.
    Note: I am not affiliated with Misumi or Misumi USA in anyway, shape or form. I am merely a satisfied customer.
    First-off, the basics:
    Machine Type: 2.5D router, primarily for wood
    Cutting dimensions: 1400mm x 1000mm x 150mm
    Total Footprint (LxWxH): 2310mm x 1290mm x 1400mm
    Construction: Aluminum with some steel
    Budget: Let's not go there ("around $5k" before software)
    The Design
    I have read a ton of build threads, bought plans from Joe, and taken copious quantities of notes over about 18 months of planning and procuring. Not to be modest, but I would say that there is absolutely nothing that is interesting or new about my build other than I am using a less well-known supplier for most of my mechanical parts (Misumi). Granted, I've got some high-end parts scavenged via the eBay gods, but the design can be summed up this way: moving gantry, underslung screw drive using ball screws and linear guides. However, since I placed this thread in the T-slot forum, a critical question worth answering: why did I choose Misumi instead of 80/20 or even Bosch, well, that may be an interesting divergence.
    I originally started with the idea of using 80/20 and going the typical eBay route for procurement. However, 80/20 does not offer any machining services on its eBay products, so I spent a fair bit of time trying to find good deals on pieces that looked to be about the right size for the machine I wanted (I was/am targeting being able to machine a half-sheet of Baltic Birch plywood - approx. 60"x30").
    While scanning eBay for good deals on stuff, I happened to find, in rapid succession, a 1500mm NSK class 5 ballscrew, a Hirata linear actuator with 1000mm of travel, a Parker Daedal linear actuator with 150mm of travel, and two THK SR30 rails that are 2100mm long. This was a big haul of high-end parts for a shade over $1500. Now to keep looking for that aluminum...
    I ended up finding a Texas company with a load of Bosch Rexroth 4590 "heavy" extrusions at approximately 7' lengths (really a bit short of that, it turns out). I did some quick sketches to be sure that I knew about how much I would need, and I placed the order, plus I got some gussets for connections and some 45" long lengths to act as posts and stringers. Good so far?
    I was on a hunt for a nut bracket housing when my Google skills led me to Misumi's website. I did not find a ball nut housing that was compatible with my NSK screw, but I did find a promotion for 30% off your first order up to $150. Figuring that I knew a decent deal when I found it, I ordered up some of the pieces that would require greater precision than I was really capable of producing with a table saw, circ saw and a drill driver, and I waited for delivery.
    Since this post is getting long and is short on pictures, let me cut to the chase on the Bosch: being unwilling to use my table saw to cut the aluminum meant that I made a hash of several of my pieces of stock. Given the quality of what I was getting from Misumi, I shifted my focus to procuring from Misumi and selling my Bosch Rexroth extrusion after the build was done. Now let's have some pictures of that mess (be gentle).
    One thing of note in the first picture: I bought the "H" or heavy Bosch Rexroth 4590 extrusion. It is made from 6063-T6 aluminum and weighs 4.15kg per meter. The two Misumi pieces in the picture are Misumi's GFS extrusion, which is 6061-T6 aluminum, and they weigh 5.22kg/meter, or about 25% more than the Bosch ones. If you bought both new, the Misumi extrusion would also be a few dollars cheaper per meter than the Bosch. Misumi's "standard" extrusion, the HFS series, weighs 4.14kg per meter, or basically the same as Bosch's "Heavy" extrusions, and they use 6005-t5 aluminum (similar to what 80/20 uses).
    Here are some thoughts from ALCOA on 6063-T6 vs. 6005-T5 and 6105-T5:
    http://www.alcoa.com/adip/catalog/pd...y_60056105.pdf
    Attached Thumbnails Attached Thumbnails bosch_vs_misumi.jpg   bosch1.jpg   bosch2.jpg   bosch3.jpg
  1. Referral for Type III class I Anodize 6' long T-slot extrusion
    By owen hooker in forum Material Machining Solutions
    Last Post: 04-14-2014, 03:45 PM
  2. Misumi Site Extrusion Prices
    By newpatch in forum DIY CNC Router Table Machines
    Last Post: 08-21-2012, 10:10 PM
  3. Looking for 8020 T Slot Aluminum Extrusion in Canberra
    By bradeyk in forum Australia, New Zealand Club House
    Last Post: 08-04-2011, 11:58 PM
  4. Anyone used Polythene pad slides for T slot extrusion
    By cweeks in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-10-2009, 12:29 PM
  5. T-slot Router Bed Extrusion
    By gotswrv in forum Want To Buy...Need help!
    Last Post: 07-11-2008, 02:16 AM
