Hello everyone,
I am interfacing a vertical NC Milling Machine with PC through a serial cable. i am using NCnet Lite(Version7) software for transfering data. Following is the machine information:
Shizuoka Vertical NC Milling Machine (3-axis)
Model no > Mill Master AN-S
Controller > Fanuc (System 6M)
How can i set the baute rate, parity etc of machine?
Machine is provided with 25 pin female port and PC with 9 pin male port.
Problem statement:
When i connect the serial cable between Machine and PC and test the serial port through NCnet Lite software. the following message appears:
Test Result
DTR/DSR Signal ok
RTS/CTS Signal ok
Communication at baudrate Testing
COM1 is not ok at the baud rate 600
COM1 is not ok at the baud rate 1200
COM1 is not ok at the baud rate 2400
Thanx for your time
