587,465 active members*
3,244 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Newb still not getting it.
Results 1 to 20 of 25
Threaded View
    Dec 2003
    673
    Several of you have given me some great advice already, but I don't "Get it" yet. Any chance someone could pull down my MCX file and fix what I'm doing wrong? I've attached the part file, the mcx file, an image of what its supposed to look like, and what in looks like when I simulate it.
    1. The first (outer countour) is ok.
    2. The second needs to ramp into the work from the right, and I can't get it to do that. It just plunges in.
    3, The third countour is supposed to be an open pocket, which ramps into the work. Couldn't get that to work, and got all sorts of odd error messages.
    The waste stock is to the Right of the part, and I did it this way so that the final op would be to cut off the stock, minimizing secondary ops.
    If you are willing to edit the file, it would probably take 2min for somebody who knows the ropes. That way I can learn from the actual code - Picture worth 1000 words and all that!
    Thanks....
    Attached Files Attached Files
  1. Please help a newb
    By hakachukai in forum Mini Lathe
    Last Post: 07-15-2007, 04:49 AM
  2. CNC newb help . . .
    By RRFireblade in forum Uncategorised MetalWorking Machines
    Last Post: 07-01-2007, 04:42 AM
  3. Newb. . . Need Help with BP series 1 CNC
    By AbleGear in forum Bridgeport / Hardinge Mills
    Last Post: 04-22-2007, 05:37 PM
  4. newb to cnc
    By krymis in forum Benchtop Machines
    Last Post: 06-15-2006, 08:23 AM
  5. Newb to DIY CNC, any help
    By tbcsoul in forum DIY CNC Router Table Machines
    Last Post: 03-28-2004, 03:10 PM
