I'm working on a program for a Okuma LB35 III and have a question. I want to use the G152 W??? to move the tailstock into position after boring the center. Once the part is complete I want to move the tailstock back to is home position. I know where the tailstock should end up at (example G152 W60.0) My question, how can I bullet proof the starting location for future runs? i.e. someone uses a longer or shorter center. Right now we are G152 W20.0 but that may change based on the variables mentioned. I see there is a variable called "VZOFW", can I used this to help solve the problem and if so how would that look? it looks like the operator should be able to set this on each run and can easily record the position he finds but is it better to have him change the W20.0 position or have the variable at the beginning of the program?
Thanks in advance to anyone that will take the time to point me in the right direction.
Thank you,
Bob Foster
