587,651 active members*
3,706 visitors online*
IndustryArena Forum > CAM Software > Autodesk CAM > Variable Depth cut in HSMworks
Results 1 to 8 of 8
Threaded View
    Jul 2018
    47
    Hello
    I am just starting out using HSMworks within Solidworks and have a machining problem as per the attached screen shot , the part has an angled bottom and i only want to machine the outside profile .
    The part is 20mm thick and needs to have the outer profile that is maximum 18mm.and help in a jig .
    i want the cutter to to offset the bottom of the part by 1mm all the way around , as the longest cutter i can get is 45mm
    If i try 2d contour as per the screenshot 1 it cuts the full depth all around
    if i use the same cutter path using Contour in the 3D menu it try's to cut a weird path around the top of the part screenshot 2
    Im sure i am missing something ??
  1. Replies: 11
    Last Post: 03-02-2016, 09:59 AM
  2. Cut Depth
    By mlk1950 in forum DIY CNC Router Table Machines
    Last Post: 03-04-2014, 04:19 PM
  3. Depth of Cut
    By Gallchobhair in forum BobCad-Cam
    Last Post: 01-23-2014, 12:45 AM
  4. depth of cut...
    By szechuanking in forum Uncategorised CAD Discussion
    Last Post: 04-12-2011, 03:30 PM
  5. Replies: 4
    Last Post: 10-26-2008, 04:42 PM
