587,396 active members*
3,630 visitors online*
Results 1 to 20 of 118
Threaded View
  1. #11
    Apr 2010
    109
    Re: imperfect circles
    This is the latest of my tests to see what's up. I used new down spiral bit to eliminate the "fuzz" I was getting with the up cut spiral. Instead of using the stock collet, I used the Precise Bits 1/4" collet and cleaned the all the seating surfaces, the collet and nut...just to eliminate as much variable as possible. This file was set up at only 0.050" depth of cut, simply to take all the load off the machine to see what happened. I numbered all the 1" blocks in the order they were cut.
  1. circles
    By oldcoalminer in forum Stepper Motors / Drives
    Last Post: 05-12-2015, 12:04 AM
  2. Bad Circles
    By lclee in forum G-Code Programing
    Last Post: 05-23-2014, 02:00 PM
  3. G01 circles
    By brian257 in forum Rhinocam
    Last Post: 04-27-2013, 02:13 AM
  4. Laser Scanner for Imperfect flat material
    By xtal2 in forum Digitizing and Laser Digitizing
    Last Post: 03-11-2013, 03:17 AM
  5. circles arent circles
    By xlr8r in forum DynaTorch
    Last Post: 01-18-2009, 06:26 PM
