Hello.
I've got a problem with changing one of optional parameter in Okuma LB 15 II. The problem is that I would like to change a lubrication frequency. Standard setting is 5 minutes. My aim is to excend this time to 10 minutes. Unfortunately I don't have any documentation to this machine. I've found only documentation to older version where we can switch parameter #16 - the operation interval of the way lubrication pump motor for the LB series lathes is set. I thought its gonna be resolution to my problem but with using this parameter i can switch max to 6 min - 5256 Input data overflow ERROR 6. Does anyone have an idea how to excend this time to 10 minutes ? Photos attached. Thank you for your help in this matter.
