587,482 active members*
2,959 visitors online*
IndustryArena Forum > Other Machines > PCB milling > need help with eagle to pcbgcode output
Results 1 to 5 of 5
Threaded View
    Oct 2011
    Hello, I am hoping some folks here use a work flow with Eagle - Pcbgcode and could shine some light on my problem.
    I'm new. I have studied pcbgcode and still can't get it right. Less than 10% of traces are output. Also it shows tool path for milling the board outline, I have the top etch as a ground plane, maybe it is cutting my ground plane, lol.
    I am in no way blaming softwares, I am sure i didn't check a box somewhere.
    eagle pic is what it should look like.
    cambam pic is what I get.
    Anyways, if someone has a minute please download the board file and see what pcbgcode outputs for you, or take a look at the pictures to see if maybe you recognize the problem.
    NOTE: Rename brd file.dxf to: brd file.brd This is an upload work-around, since the Eagle .brd file extension is an invalid type.
    Eagle 6.1
    pcbgcode 3.5.2.11
    cambam 0.9 for viewing paths and editing
    Mach3
    all traces on board are 10mil, clearance 8mil
    my setup for pcbgcode is:
    default .001
    max .008
    step size .005
    tool size .007
    Attached Files Attached Files
  1. Fun Eagle
    By drawbar in forum WoodWorking Topics
    Last Post: 01-23-2011, 08:05 AM
  2. Eagle CAD importing
    By Blizzy_206 in forum Uncategorised CAM Discussion
    Last Post: 03-10-2010, 05:07 PM
  3. Eagle CAM Processor output - Mach3 Size issue
    By deleteallusers in forum G-Code Programing
    Last Post: 05-02-2007, 03:14 PM
  4. Eagle CAD
    By jhwatts in forum Uncategorised CAM Discussion
    Last Post: 01-26-2006, 11:41 PM
