587,497 active members*
4,472 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Control Techniques NT series AC servo testing
Results 1 to 2 of 2
    Mar 2008
    18
    Is there a way to test the function of a 3 phase AC servo without buying the appropriate drive?
    ie - if I introduce 120v across two motor terminals to see if it'll spin will I destroy anything?
    The motor in question is an Emerson / Control Technique NTE 345 CONS 0000
    Dec 2003
    24220
    Re: Control Techniques NT series AC servo testing
    No, unfortunately that won't test it, also you need to know the commutation method.
    It has three stator windings, if the right commutation were fitted, you could run it as a BLDC.
    Either way you need the appropriate drive.
    Al.
    Albert E.
  1. Modbus TCP with Control Techniques SK Commander VFD for spindle control
    By fishin_fl in forum Mach Software (ArtSoft software)
    Last Post: 08-26-2013, 04:07 PM
  2. Replies: 4
    Last Post: 12-20-2012, 06:11 AM
  3. control techniques AC Servo
    By bertcnc in forum Servo Motors / Drives
    Last Post: 05-19-2011, 03:19 PM
