587,283 active members*
3,704 visitors online*
IndustryArena Forum > CAM Software > Mastercam > yes im just a nother noob on mastercam
Results 1 to 13 of 13
    Jan 2010
    5
    Question yes im just a nother noob on mastercam
    ok im a student and my school just got a brand new cnc mill with mastercam x4 and the old mastercam 9 but the lessons that came with it are only for 9 and i would like to learn the x4. i just got a very complex rhino file seen here http://www.cartertools.com/3Dpath.html and i would like to know how tho tool path it and all that.
    Thanks in advance
    Jun 2006
    48
    post the file and i can write some tool paths
    Jan 2010
    5
    here is the file it is a rhino 3D file. if you could just post the mastercam fle so i can see how you did it that would be great.
    Attached Files Attached Files
    Jun 2006
    48
    is this for a vertical mill or a horizontal mill, the reason bieng the setup is slighly diffrent
    Check out eapprentice.net Mastercam training from A-Z
    Jun 2006
    48
    here it is, you will need the mu2 update for mastercam to open this file
    goto to the mcam website to find it
    these toolpaths are definetly not optimal for this part by far but you should get the jist of how to surface machine, starting with larger tools and working ur way down
    u dont have to use ball mills to do you first roughing i prefer to use a radiused end mill maybe a .015-.025 corner rad depending on the application could be as high as .06 cr again its all in how things work and what makes good quality parts
  1. Replies: 36
    Last Post: 05-31-2009, 11:06 PM
  2. MR.NOOB.....thats me......
    By MR.Pogi in forum Fadal
    Last Post: 03-11-2008, 01:12 AM
  3. 'Nother newb need help. Gibbs/Post/Mach3
    By RRFireblade in forum Screen Layouts, Post Processors & Misc
    Last Post: 02-09-2008, 11:05 PM
  4. yet another noob
    By mastermoparman in forum Community Club House
    Last Post: 09-18-2006, 07:22 AM
