587,794 active members*
2,965 visitors online*
Results 1 to 2 of 2
    May 2009
    54
    what diameter acme rod?
    I asked before, but the discussion got side tracked. )
    Is there a chart somewhere, or rule of thumb that tells me how fast I should spin a diameter of Acme threaded rod to keep wobble out?
    As of right now I'd like to run steel 1/2" acme, 5ft long at 200rpm, captured on both ends with a ball bearing and a thrust bearing. Any thoughts? What is the max revolved speed of 1/2"?? 5/8"??
    Thank you,
    May 2009
    54
    Well, never mind. I found it. Supposedly I can spin 1/2" acme over 600rpm.
    http://www.nookindustries.com/engine...ticalSpeed.cfm
  1. can stub acme be changed to acme
    By osiris999 in forum MetalWork Discussion
    Last Post: 01-28-2009, 09:00 AM
  2. Shaft Diameter, LeadScrew Diameter, Motor Torque?
    By cnc-newb in forum DIY CNC Router Table Machines
    Last Post: 12-24-2007, 09:51 PM
  3. Shaft Diameter, LeadScrew Diameter, Motor Torque?
    By cnc-newb in forum Uncategorised MetalWorking Machines
    Last Post: 12-15-2007, 04:25 AM
  4. .249" diameter acme screw?
    By Macht_Tot in forum MetalWork Discussion
    Last Post: 08-08-2007, 01:20 AM
  5. Acme Internal Thread 1 ½ - 0.250P-2.000L-ACME-2G-LH (8 START) Help
    By pandiyan.innova in forum Community Club House
    Last Post: 11-16-2006, 12:47 PM
