587,489 active members*
3,202 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Surface to Surface Filleting and Trimming
Results 1 to 7 of 7
    Jan 2005
    21
    MasterCam Version 9
    Have been trying to fillet the edges of the attached part and can only get it complete to the shown stage.
    Using surface/surface fillet with trim surfaces enabled, but the upper flat surface does not trim. Could not get the 2 surfaces to fillet in a single operation and had to use pick a pair and work my way around the contoured part to obtain the shown result.
    Also have been trying to surface/surface trim the 2 protruding surfaces at the part pointed end but no success there either.
    Then tried surfacing the part as drawn but I keep getting a "self intersecting" message. Followed the prompts to change color of the intersection but never see it show up on the drawing.
    Would really appreciate someone taking a look and give me some guidance as to what I am missing and doing wrong. Feel like I am close but just can't get over the hump.
    TIA,
    cem
    Attached Files Attached Files
    Jan 2008
    123
    Not at my MC computer today but make sure both your surface normals are facing the same way
    Jan 2005
    21
    Checked the norms and had 2 reversed. Flipped the two but still get the message of self intersecting surface.
    I tell it to change the color when asked but can never see anything change color on the screen.
    Dec 2008
    3126
    Checked your file
    Problem area is in the 2 tight rad " fingers"
    Turn on shading , you can see the swept radius fillets have "top hats" ( these are the self-intersecting surfaces )
    Remedy
    Extrude your profile , before filleting the top face edges ( you may have problems filleting this particular area due to the actual geometry )
    Extruding will give you a solid block, as a starting point
    Jan 2005
    21
    Extruding and then filleting the solid worked like a charm. See attached.
    Can you suggest a strategy for surfacing this. I get to a point in solid surfacing where I am asked to select a drive surface but can find nothing that will highlight and select.
    My first attempt at surfacing a solid.
    Thanks,
    cem
    Dec 2008
    3126
    As a beginner, create surfaces from solid
    1- change color and level
    2- <create><surfaces><next menu><from solid> ( solids=Y faces=N ) select the solid <done>
    3- turn off level 1
    4- select the surfaces now created that make up the filleting part for the surfacing op
    BTW should you be using a Radius form tool (RAD MILL) for this operation ?
    Jan 2005
    21
    Hi Steve,
    Think I have it.
    Thank you so, so much for your help.
    Will let you know how it turns out.
    cem
  1. Trimming surfaces for surface milling
    By data-matique in forum Mastercam
    Last Post: 12-14-2008, 11:45 PM
  2. surface help
    By msn_jrd in forum Mastercam
    Last Post: 11-20-2008, 01:28 AM
  3. cut from surface
    By Flankman in forum Musical Instrument Design and Construction
    Last Post: 09-03-2008, 12:49 AM
  4. *.obj to surface in MX2?
    By tesart in forum Mastercam
    Last Post: 05-28-2008, 09:41 PM
  5. MDT 6 Surface Cut
    By djzepp in forum Autodesk
    Last Post: 04-11-2007, 04:56 AM
