587,913 active members*
3,805 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Programming a bar puller in X2 on a lathe
Results 1 to 2 of 2
    Nov 2006
    303
    We have a basic slant bed 2 axis and have always had to hand program a bar puller because I never took the time to look into getting it to work out of X2. We have been able to go to the stock advance tab and create a path but have no puller tool in any tool lists and do not see an easy way to create one. The backplot just shows an OD tool coming in to pull the bar. When we post the work, there is always an error, so we hand code it and move on. Any ideas what we are missing here? Do we need to create a tool in the tool list to do this? We looked at some samples files in X2 and they show a custom puller in the list but no idea how to get it there or if we need to.
    Also, this may seem a very stupid question but I never figured out why I cannot switch tools very easy on the lathe. With the mill, you can go type in a different number in the op parameters but if you do that on the lathe, it will only ask if you want to change all ops or not. "No, I don't". I just want to change that one op to use a different tool. I either change all ops using that tool or I get no change at all. What am I missing? Could this be a settings issue?
    Mar 2006
    1013
    Pick another tool from the library and give it a new #. That's the right way to do it, even in Mill. If you pick the same tool it will ask if you want the same # or a new #.
    Mike Mattera
    Tips For Manufacturing Training CD's, DVD's for Mastercam, SolidWorks, Inventor, G-Code Training & More
    http://www.tipsforcadcam.com
  1. Lathe programming
    By mcm1961 in forum Haas Lathes
    Last Post: 08-20-2021, 02:35 PM
  2. Bar puller programming
    By FUN4ME in forum Haas Lathes
    Last Post: 02-27-2017, 11:12 AM
  3. Cnc Lathe Programming
    By millmonkey1 in forum Employment Opportunity
    Last Post: 02-04-2011, 01:17 PM
  4. CNC lathe plus Bar Puller help
    By SeaSchell in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-06-2006, 12:44 AM
  5. Bur Puller programming
    By Genie in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-08-2006, 01:48 AM
