587,745 active members*
2,753 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Question about parameters - Fanuc OT-C
Results 1 to 5 of 5
    Jun 2006
    40
    I am going through my parameter list because the previous owner had changed several (about 100 to 150 parameters) and have a few questions. First, does anybody know where I can get a copy of the Fanuc OT-C parameter manual? My machine only had the Fanuc operators manual. I have hear rumors of them being available as a downloadable copy but i would also settle for having to purchase the paper manual. Second, I have a printout of the original parameters and several hundred of the parameters are missing leading zeros. Is there a problem with this? For example, parameter N0556 is 00004800 on the printout but shows as 4800 on the CRT display. Hundreds of the parameters only have a single 0 where the printout has 00000000. Just curious if I need to add all those zeros back.
    Dec 2003
    24220
    Send me a P.M. with email add.
    the lack of leading zero's are normal.
    Al.
    Albert E.
    Nov 2007
    3
    the parameters are generally shown as 8 bits running from right to left with the 8th zero being the "0" bit ex 76543210
    00000001
    Sep 2006
    31
    I purchased a parameter manual for an O-MD from Fanuc for $8.00 plus shipping. 1-888-FANUCUS
    Jun 2006
    40
    Got it covered. Thanks.
  1. Need help with PC Parameters on a Fanuc 6M
    By jimlinn in forum Fanuc
    Last Post: 02-08-2019, 03:16 AM
  2. fanuc 11m parameters
    By sootblower in forum Fanuc
    Last Post: 08-11-2018, 08:30 AM
  3. Fanuc 0T G83, G84 parameters
    By davisboys in forum Fanuc
    Last Post: 03-18-2007, 05:29 AM
  4. Fanuc 3M Parameters
    By nastek in forum Fanuc
    Last Post: 12-29-2006, 02:35 PM
  5. Fanuc 18T - Parameters
    By pinguS in forum Fanuc
    Last Post: 04-12-2006, 12:20 AM
