587,192 active members*
2,466 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > CNC (Mill / Lathe) Control Software (NC) > HELP. Do I need soft limits set to have the CNC slow down to hard limits
Results 1 to 2 of 2
    Sep 2003
    1473
    Mach3, Vectric 11, Gecko G540, ESS, both Y axis driven
    I am adding homing and limit micro switches to my DIY CNC. Do I also need to set up the Soft Limits to have it slow down as it approaches the Limit and Home switches, or is the slow down feature available in the Homing and Limit switch setup?
    Jan 2005
    15362
    Re: HELP. Do I need soft limits set to have the CNC slow down to hard limits
    Quote Originally Posted by Mr.Chips View Post
    Slowdown has nothing to do with Soft Limits, set your Homing at a speed that does not need to slowdown before the switch, 20IPM works just fine for most.
    Soft-Limits are easy to setup after you have established the Home Position, and are worth setting up takes about 1minute max per axis to do.
    Mactec54
  1. Replies: 0
    Last Post: 04-14-2021, 02:25 PM
  2. MACH3 SOFT LIMITS – Main screen soft limit button will not illuminate
    By HANZC in forum Mach Software (ArtSoft software)
    Last Post: 02-14-2019, 12:46 AM
  3. Mach 3 - "Software Limits" Can't turn off Soft Limits
    By MattWiese in forum Mach Software (ArtSoft software)
    Last Post: 10-23-2017, 05:10 PM
  4. Setting up Config >Homing/Limits Dialog (Motor Home/Soft Limits)
    By CStevens6 in forum Mach Software (ArtSoft software)
    Last Post: 07-18-2013, 04:19 AM
  5. Colchester 2000 CNC soft limits
    By randdprecision in forum Colchester Tornado lathes
    Last Post: 10-26-2009, 10:17 PM
