587,402 active members*
3,050 visitors online*
Results 1 to 5 of 5
    Jun 2017
    3
    goto zero single axis
    Hi all, great forum and very useful for us newbies.
    My question is what is the easiest way to send only the the Z axis to its zero position?
    Apr 2003
    540
    Re: goto zero single axis
    Manually you can just enter the gcode to go to Z0, or set up button(s) that will do it without typing it in. You need to do some research on Gcode and read the Mach manual.
    Jan 2018
    1516
    If doing it often I'd edit an existing G code in notepad for G0 ZO.
    I have one saved for G28 at days end.
    Something like this I edited from a previous slot program.
    (3MM SLOTS)
    (T3 D=3. CR=0. - ZMIN=-17. - FLAT END MILL)
    G90 G94 G91.1 G40 G49 G17
    G21
    G90
    (SLOT3)
    G0 Z0.
    M30
    This will only move Z to 0. Just load and start.
    Jun 2017
    3
    Thanks guys, great help as always.
    Nov 2012
    1272
    I made my own homebrewed Mach3 screen with 3 important buttons for each axis:
    - Zero
    - Go to zero
    - Snap (go to the nearest millimeter).
    Attachment 425860
  1. Z axis and GoTo Zero crash
    By Eveb in forum Mach Software (ArtSoft software)
    Last Post: 06-16-2018, 09:29 AM
  2. I NEED INFO ON THE TB6560 SINGLE AXIS BOARDS WITH THE MACH3 5 AXIS BOB
    By lmlamb in forum Uncategorised WoodWorking Machines
    Last Post: 02-09-2017, 06:46 PM
  3. Mach3 z axis goto zero not working
    By Inkable in forum Mach Software (ArtSoft software)
    Last Post: 10-29-2015, 04:13 AM
  4. Replies: 7
    Last Post: 07-14-2014, 11:11 AM
  5. 5 axis breakout board and 3 single axis drivers tb6560, not working
    By MROX15 in forum Stepper Motors / Drives
    Last Post: 11-06-2013, 07:34 PM
