587,770 active members*
3,261 visitors online*
Results 1 to 3 of 3
    Jul 2005
    194
    Angry Sqeaking X Axis
    I've had my SlantPro since September and use it every few days. I was running a part today and noticed that the X axis is squeaking. X travel at high speed tends to stall the motor. I have a manual oiler that I pump every day or so and have filled it a couple times. I also reached up under there and it's oily and looks fairly clean with a mirror.
    Sounds like by X gibs need adjusting, but why now? I probably have 200 hours on it.
    Jul 2005
    194
    Re: Sqeaking X Axis
    So I went and ate and stopped thinking about it and then went back and moved the little brake lever on the X axis so it's disengaged so its all back to good. Does this mean my brake is bad?
    Dec 2013
    5716
    Re: Sqeaking X Axis
    Sounds like the brake is not being powered when it should be. Could be the brake itself, wiring, or a relay in the panel. Check the brake coil with an ohmmeter. Not sure what the power on voltage should be.
    Jim Dawson
    Sandy, Oregon, USA
  1. Replies: 16
    Last Post: 09-11-2017, 10:31 PM
  2. Replies: 0
    Last Post: 04-27-2016, 04:08 PM
  3. Replies: 1
    Last Post: 11-17-2015, 07:37 PM
  4. Replies: 0
    Last Post: 08-04-2013, 05:30 AM
  5. 5-axis, 4-axis, and 3-axis CNC Router manufacturer
    By roctech in forum Roctech CNC Routers
    Last Post: 05-24-2012, 09:12 AM
